2012 F350 Pulling to Right when Braking
My New F350 6.7 pulls to the left continously I am betting on a hung caliper when I drove it home the first time I could smell brakes I just assumed it because it was new but now I have 1400 miles and it tugs the wheel to the left every time.... I will take it in to the dealer and I will get a fiesta to drive home and pull my trailer with in return.... LOL
Well guess what?
The damn thing was pulling right...hard enough that if I let go of the steering wheel it pulled me over to the next lane on the highway!
So I stopped on the side of the road and checked the heat of all the wheels and they were hot, but not too hot to touch. Fronts were a bit warmer than the rears which is typical so I carried on driving home. On the way I waited until there was no one around me before attempting the following:
Tap the brakes fairly hard to see if that corrected the problem....no
My wife witnessed this and was also convinced it was not normal.
Since the issue in the early days it never really reared it's ugly head after the visit to the dealer for the no fault found, so I passed it off as a fluke. Well based on some of the other posts here (searched for "caliper" on the 6.7 forum) this is not a fluke and I will get it in to be looked at ASAP. Need an oil change anyway
Keep you all posted!
Trent310, Michael53 - how are your brakes doing?
Anybody else lately?
Left Front
Right Front
Left Front
Right Front
But I am still looking for feedback from those more knowledgeable than me on the subject so I can be well informed before dropping it off.
An additional note: I have to drive several miles in city traffic to get it to do it, so heat is definitely a factor
Just scheduled it in tomorrow AM, will post outcome.
Good luck at the dealer with this.
Interesting, I don't think that is the case with mine. Mine just seems to have a left pull all the time. On local two way roads, the truck holds the crown or may ride down the crown, but in the left lane on a highway, it always wants to go left.
Thanks!
on
It hasn't done it again for me but I still have a new caliper on order and they will change it out under warranty for me once it shows up. It got hot enough to turn the rotors a blueish hue and the dust cover over the pistons is melted but so far the seal has been holding up and not losing brake fluid.
OK here is the update.
Picked up the truck yesterday afternoon and it no longer pulls to the left
They basically greased the pins (there was verbiage about removing clips and so forth - did not want to bore you with what was removed as it was obvious it was to remove the the caliper).
But I have noticed that it appears I am back to the initial problem of it pulling slightly to the right.
It is more evident the harder you brake (bear in mind that it is much easier to tell if you are not holding tightly onto the steering wheel).
Now I did ask them to check both fronts....but the paper work did not indicate that they did the passenger front, just said that a test drive confirmed that it no longer pulled to the left.
It could be that they can only do one thing at a time on a service ticket maybe?
Anyway, It is no where near as severe as the pulling left problem was, so I want to get a little more seat time first before I pass judgement if it is just normal or an issue.
Here is the rub....truck is in tomorrow for the air bags and compressor and then tuesday it's off to the cabin in the mountains.
Luckily I am not towing or hauling anything (again ...but maybe that's a good thing at the moment) up or back.
BUT....I might just haul that big azz 14' boat....should I be concerned????
Seriously...Everybody have a nice holiday weekend(s)
P.S. Glad the truck is no longer pulling and I hope the bag installation goes smooth tomorrow!
#28
Provided the console safe arrives before you put the boat in there, I'm sure it will be safe. That safe looked pretty secure.
Now that there was funny.....
Thanks Savage!
Too hot to mess with loading and weighing Sunday...gonna wait until it is below 110 at least
Thanks Savage!
#29
FishingNut,
I had pretty much the same issue as you a few weeks ago- pulling hard right. The dealer found one left caliper piston cracked and the other one leaking- 5 month old truck, 10K miles. They checked the right side front caliper which also appeared to be defective. Replaced both front calipers and turned the rotors on the truck. All has been fine since.
Here is the thread on this I started: https://www.ford-trucks.com/forums/1...r-problem.html
#30
mine too!
I've taken it to Ford twice about this same issue. I took delivery of the truck 4 weeks ago, and noticed that it pulled to the right when I brake maybe a few days after I got it. (only 200 miles on it at that time)
The first time I took it to the dealer, they said "yep, it a stuck caliper, we replaced it with new pads, that was the first we've heard of that issue"
So for a few days at the most, it was fine, I didn't notice it pulling. Then it started again while I was pulling a trailer (only pulling like 7-8,000 lbs.)
I took it to them this week and they are saying that it's just a characteristic of the truck and that it's sensitive to the crown in the road. ????? hmmmm, not sure what to do or think. Maybe get another dealers opinion??
I notice my fuel mileage went down too! Even after I reset and watched how I drove.
