61 Fuel Sending Unit Part Number Help
Old 05-17-2011, 10:32 PM
rrob's Avatar
rrob
rrob is offline
I am looking for a fuel sending unit for my 61 Econoling pick up. Would anyone know of anyone parting one out, any part number(s) or of any other models that used the same unit. Any source help is appreciated!
Thanks.
Old 05-25-2011, 04:41 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Welcome to FTE
C2DZ-9275-A (replaced C0DZ-9275-A) .. Fuel Sending Unit Assy-Includes Float & Gasket / Obsolete
Applications: 1961/67 Econoline / 1960/64 Falcon except Ranchero/Station Wagon and Sedan Delivery.
GREEN SALES CO. in Cincinnati OH has 8 = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY has 18 = 606-787-5293.
But, do not buy one until you check the float, the usual cause why the dash fuel gauge reads in-correctly.
The float is made from two pieces of copper soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank!
C0AZ-9202-B .. Fuel Sending Unit Float / Available from Ford.
Applications ~ ALL 1957/79 Pasenger Cars & Trucks / 1961/79 Econolines / 1966/79 Bronco's.
MSRP: $14.49 // FTE sponsor PARTSGUYED.COM (Horizon Ford in Seattle) price: $10.43.
COAF-9276-A .. Fuel Sending Unit Gasket / Available from Ford.
Same applications as above except 1961/77 F/N/NT Series trucks with in-cab fuel tanks.
MSRP: $0.63 // PARTSGUYED.COM price: $0.46.
Old 05-25-2011, 05:02 PM
rrob's Avatar
rrob
rrob is offline
Thank you for the reply, I appreciate it. I took the tank out and had it cleaned out and re-lined as it was badly rusted. The unit itself is in poor shape so I have called Green Sales and they are sending one now.
Thanks again for the help!
Old 03-05-2012, 01:56 PM
redhedbronco's Avatar
redhedbronco
redhedbronco is offline
Does anybody have the ID/OD and material thickness of this gasket? Have to replace with Viton and need dimensions of gasket to cross reference. TIA
Old 03-06-2012, 08:58 AM
redhedbronco
Anybody have a spare they can measure? Thanks.
Old 03-08-2012, 02:31 PM
NumberDummy
COAF-9276-A: It's actually a neoprene O-ring = 2.41" I.D. x 2.58" O.D. - .125" thick.
The same puppy was used on ALL fuel tank sending units installed in: 1960/79 Passenger Cars, 1961/79 Econolines, 1966/79 Bronco's and 1967/79 F100/350's except 1967/77's with the in-cab fuel tank (uses a cork gasket).
Available from Ford, prolly every autoparts store for less than a buck.
Old 03-10-2012, 03:44 PM
redhedbronco
NumberDummy, thank you for the dimensions. I have a 69 Bronco with a Cummins 4bt thats been in it since 06-07 and the neoprene is not diesel rated and is disinigrating and have heard bio is even more detrimental. Thanks again for information.
Beast 6.9 idi
12-26-2016 12:16 PM
Martin Torres
12-15-2016 11:25 AM
gdp1701
Large Truck
10-19-2016 04:34 PM
74 F350 SCS
11-09-2014 07:55 PM
tekrsq
10-28-2011 04:47 PM
Quick Reply: 61 Fuel Sending Unit Part Number Help
