White smoke after coolant flush
I have an '06 that I purchased 1 year ago. Never used any coolant and temp differential was 7-9 degrees at 70mph open highway. Read the posts here about Ford Gold coolant, and did the full flushes with Restore, Restore Plus, and distilled water. Replaced with an ELC and added Desielite filter. Immediately after the flushes with 45 minutes high idle each flush (a 6 hour ordeal) I drove the truck on the highway and noticed hugh amounts of white smoke from a dead stop. This has settled down to only a little at startup...and then sometimes not at all. I have noticed that the temps are now between 5-7 degrees, but I am using about 1/4" coolant in the degas bottle over a 2-3 week period. EGR cooler? Head gaskets?
agree
Lets see if I understand this.....You had an 06 6.0 for a year and deltas were good at 7-9 degree at 70 mph on the open road.....WITH Ford Gold, read about all the bad things about that and run home and immediately swapped it out for the GOOD stuff and blew the EGR cooler? Interesting, now I'll admit you don't state the mileage you have on this truck BUT it IS an 06 and was doing good on FG.....mmmmm, I'm glad it all worked out for you but I think there is a lesson to be learned here about fixing something that's not broke. jmho
In some things it pays to be proactive, and others it doesn't.
With the 06, the following proactive things are a good idea (IMO):
1. FICMrepair.com upgraded FICM
2. STC fitting replacement
3. Dummy plug and standpipe upgrades
4. Fuel pressure regulator "blue spring" installation
An upgraded alternator is a very good idea, but not everyone "needs" it.
Gauges are a must.
Gauges are a must.
An upgraded alternator is a very good idea, but not everyone needs it.
Gauges are a must.
Gauges are a must.
I've read a bunch here about how to keep the 6.0 rolling and happy but you gave a nice list, made me curious since all the years seem a bit different from each other.
Thanks
Well I am not Mark "bismic" lol. But his suggestions would apply to your 07. Good chance some of it may of already been done, blue spring, stc fitting, dummy plugs. Wouldn't know unless you had paperwork or knew the po of the truck or just tear it down and look at it. And no I am not trying to fill your shoes Mark. Way too big for me.lol
Thanks "bobcat," ha! I seem to usually browse the forum on the mobile site and forget about signatures and names. But honestly, I appreciate anyone's opinion, the collective minds here have great information. The main reason Mark's post caught my eye is because he wrote options in one small succinct post wheres often the same information is either scattered in lots of posts or contained in lengthy "to do" posts.
You brought up a couple good points on what's been done that I can answer but I hate to hijack this thread, so maybe I'll start one and you guys could weigh in there.
Teds
01-18-2012 06:22 AM
Champdog21
11-03-2008 09:16 AM
