How many Miles are on your 4.6/5.4 Modular Engine ?
Old 12-31-2012, 09:02 PM
BassFantasizer's Avatar
BassFantasizer
BassFantasizer is offline
Received 4,664 Likes on 2,600 Posts
'97 F150, 4x4 Off Road, 5.4. Ordered in July of '96, delivered October. One of the first half tons with the 5.4. Original owner.
198,000 miles. 130,000 local, 68,000 highway, 30,000+ pulling a ton or more.
The motor still doesn't burn oil. Never added a quart between changes at 4,000 miles. Original transmission.
My only beef is the rear end. It's junk. Always has been. Ford should have replaced the entire axle, but opted to put in a set of gears. Over and over again. Gone through 6 sets. Trying to figure out if I want to dump $2,500 to rebuild a junk rear end or get a used axle from Pic N Pull.
Bass
  #62
Old 01-04-2013, 10:02 AM
chrisgavlik's Avatar
chrisgavlik
chrisgavlik is offline
the wife's truck 01 f250 2wd 5.4l has 209k on it and still counting, original timing chains. she burns about a quart and a half of oil every 3k but she still pulls a race car on trailer every saturday with no problems. great truck
  #63
Old 01-11-2013, 05:35 PM
gooddialtone's Avatar
gooddialtone
gooddialtone is offline
My 2005 F150 Lariat CrewCab has 110K miles. Original owner. Use every day in local driving and about 4K or 5K miles per year towing a 7100# travel trailer... Normal oil change and service every 4K miles. Original Plugs, runs like a top... Only maintenance is brake job at 80K miles. If someone is looking for a used one, I would say anything that looks like it has been taken care of and has less than say 100K miles would be a great truck with another 100K trouble free miles..
  #64
Old 01-20-2013, 03:23 PM
Mustang6147's Avatar
Mustang6147
Mustang6147 is offline
My 06, 5.4 in a SD 4x4 has 77000 trouble free miles.
I have changed the fuel filter 10 times, tranny fluid and filter 2x Axle fluid 1x, and antifreeze 2x, transfer case 1x. greased my caliper slides more then I can remember. and am still runnin on the original BFG's rotated every 5000.
I enjoy doing maint on my truck
I also opted to have Ford do the plugs at 50,000 miles while it was under warranty because of the known plug issue.
  #65
Old 01-22-2013, 01:15 PM
drey04's Avatar
drey04
drey04 is offline
getting close to 220k on my truck in my sig
  #66
Old 01-25-2013, 03:18 PM
BigG~'s Avatar
BigG~
BigG~ is offline
1997 Expedition {Bauer}
Hey guys,...
I just turned 188K in my '97 Exp.~~4.6L 7" lift w/35's...
I purchased truck used at 30K and Luv everything about it..
1~starter, and your normal wear n' tear....
Trans. is just starting to lose 2nd gear... Other than that I wouldn't trade it for nuttin'.... Hope to turn it over again, engine purrin' like a kitten....
Thanx, G~
  #67
Old 01-25-2013, 11:34 PM
gcspray's Avatar
gcspray
gcspray is offline
94 K on a 2001 Expedition AWD with the off road package. The only issue we have had is the famous plastic intake manifold cracked at 87K. The dealer replaced the intake, and did the 100K tune-up since I was paying the labor to remove all of the parts anyway.
We used a Dorman aftermarket intake, and so far so good. The mechanic said that the Dorman unit uses an O-ring to seal to the heads, and that is different than stock. He was not sure how it will hold up, but said that it went together nicely.
She runs great, always has. We have not had issues with the spark plugs, and the mechanic told me that a lot of it has to do with using the proper torque when installing them. Time will tell...
For service, I do that part myself using Castrol GTX 5w20 and Motorcraft filters. The oil gets changed at 3K without fail. No leaks, no smoke, and the oil still looks clean and full at the 3K mark.
My son has a 99 F250 4x4. His 5.4 spun a main bearing at 140K. He was not running the correct oil in it. He was using 20w50 and changing it infrequently. He had a remanufactured Ford engine installed and now has 70K on that one, with 210K on the truck. He learned his lesson about the 5w20 oil and changing it and the filter on a regular basis.
My sister has an 02 F150 Supercrew 2wd. They raise quarter horses and travel constantly pulling a four horse gooseneck trailer. The truck has 195K and is original. It looks like crap, but runs great. The oil probably gets changed once each 10K or so, and they get it serviced at the quick lube places, so who knows what kind of oil they put in it.
That's our 5.4 story.
  #68
Old 02-10-2013, 06:31 PM
tkarasch's Avatar
tkarasch
tkarasch is offline
1997 F150 5.4 Sold it 4 months ago with 310,000 still see it around town. Changed plugs once at 208,000 replaced alternator and startor once and changed trans fliud once. I cant say I treated this truck as well as it treated me, oil changes were done about every 7,000 to 12,000 miles
  #69
Old 02-12-2013, 09:53 AM
rus_rog's Avatar
rus_rog
rus_rog is offline
04 5.4 F150 w 174K so far....
I just put 1000 miles on it last weekend driving to Baton Rouge and back to Fort Worth. Original plugs, original belts and hoses. Truck still runs like a top. It's had 0W-20 Mobil 1 all it's life and a fresh dose every 5000.
It runs perfect now but I am worried about the plug situation. I know they need to be changed and (so I have heard) have the coils replaced. I typically do all my own service but the coils have me worried.
Great site by the way....
Russ Rogers
  #70
Old 02-12-2013, 02:09 PM
joe28540's Avatar
joe28540
joe28540 is offline
My 04 F150 FX4 with a 5.4 just turned 451,000 miles young this past weekend. Original drivetrain.
  #71
Old 02-13-2013, 07:29 AM
JWA's Avatar
JWA
JWA is online now
Received 1,391 Likes on 1,100 Posts
WOW! Have you owned the truck since new?
That's amazing!!
  #72
Old 02-13-2013, 07:48 AM
joe28540's Avatar
joe28540
joe28540 is offline
No not since new. I want to try and keep till it hits 500k.... No special treatment either, serviced with Quaker State High Mileage every 5K since 100K...We did change out the cam phasers and timing chains & tensioners at 430K. I also put new cats on last week. But thats pretty much it aside from preventive maint...
  #73
Old 02-13-2013, 10:15 AM
wi_saint's Avatar
wi_saint
wi_saint is offline
1999 F250 Super Duty.
166500 range.
  #74
Old 03-09-2013, 01:38 PM
millionmileford's Avatar
millionmileford
millionmileford is offline
mileage
Well my old girl was doing good till she just hit 415,263 miles. She is a 2001 ford f150 supercrew. I have a miss and loss of pwer under load with the usual lean fuel codes on banks 1 and 2. Have checked all vac lines and fittings resealed the intake,new plugs and cops, anyone have any ideas . It done this suddenly on a trip thru kansas. Ever since i get a cel that flashes with engine shutter at cruise. give it gas its happy.
  #75
Old 03-11-2013, 08:33 PM
woodworker63's Avatar
woodworker63
woodworker63 is offline
woodworker63
2001 f250 with 5.4 now has 197000. never a problem.just regular service, also no oil leaks, even I can't believe it.
Quick Reply: How many Miles are on your 4.6/5.4 Modular Engine ?
