How many Miles are on your 4.6/5.4 Modular Engine ? - Page 12 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Reload this Page >
  #166
Old 03-23-2015, 01:49 AM
kermmydog's Avatar
kermmydog
kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
My 99 P71 has 153,547 miles and run great so far. At 67 mph I get around 22.4-22.8 mpg. 3:55 gears. At 80 mph the mileage drops to around 17.5-18.3 mpg.
  #167
Old 04-06-2015, 09:03 PM
leardvr's Avatar
leardvr
leardvr is offline
leardvr is starting off with a positive reputation.
'97 E150 225xxx hums alone all day.
  #168
Old 04-11-2015, 05:11 PM
liljohn22
liljohn22 is offline
liljohn22 is starting off with a positive reputation.
F250
Originally Posted by Katmandu View Post
Post as many details as possible.
I have a 2000 f250 with 354500 miles. Second owner. I work the crap out of it too! I haul scrap metal. Still runs great. Replaced flywheel, starter, alternator, and fuel pump
  #169
Old 04-12-2015, 01:45 AM
bayou barataria
bayou barataria is offline
bayou barataria is gaining momentum as a positive member of FTE.
2008 f-250 cclb used for work mostly hot weather city driving just turned 105k. nothing major yet.
  #170
Old 04-19-2015, 05:32 PM
brokenleg
brokenleg is offline
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
I have a 2001 with the 5.4 2 valve. It has the offroad package. 3.55s. best its done is about 17 on a trip. Have replaced 6 COPs. a fuel pump, and the intake. the 5.4 doesn't have the power like it should. exhaust manifolds leak. Ive not been 100% happy with this particular truck. 145K now. Bought it when it had 125K. and that was 4 years ago. Most of the time it has a trailer on it too.
  #171
Old 04-19-2015, 11:17 PM
Frdtrkrul
Frdtrkrul is offline
Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.
Just recently rolled 260,000 miles on the old 99. Still has a mis-fire, losing coolant (even though I added a whole bottle of Bars stop leak), burns about a quart of oil every 700-1000 miles. With the weather getting warmer mileage is going from 8-9 to 10-12 when driving on the highway other wise its in the crapper in town doing anywhere from 55 to 30.
  #172
Old 04-20-2015, 08:26 PM
bayou barataria
Sounds like you may have a head gasket leaking. Is it running hot?
  #173
Old 04-27-2015, 01:04 AM
Frdtrkrul
Nope. Temp stays just fine. After about 2 months or so after I last topped off the coolant, the res. is about half way full. I might have a head gasket leak...but with how many miles are on it and how badly the body is rusting away...not worth the time, money or hassle to fix it.
Water temp gauge stays right in the middle.
  #174
Old 04-27-2015, 01:17 AM
StangMan's Avatar
StangMan
StangMan is offline
StangMan is starting off with a positive reputation.
The '00 F150 Sport 4.6 just lost a COP at 200,500 miles, taking the opportunity to do all the coils, plugs, flush the coolant system, and install a new transmission cooler w/ fan.
The '98 Continental is up over 260,000 miles on it's B-head 32V 4.6L, runs like a top,just yanked the mufflers for something a little less bland, lol.
  #175
Old 04-27-2015, 10:37 PM
bayou barataria
I would have to agree with you, if you have the means a new truck would be better than spending the time and effort of fixing an old truck. If it were a 1979 model I would probably fix it, those old trucks had a heavy duty body and were much better built.
  #176
Old 04-28-2015, 04:07 AM
Frdtrkrul
As much as the truck has been reliable other than crappy fuel pumps overall its been great. But Ford really should have engineered it to be easier to work on. Tucking the engine under the cowl making access to 7 and 8 cylinder nearly makes it a nightmare and ESOF kind of sucks. I might have to go to a different brand until the 2011 trucks are cheaper to buy.
  #177
Old 05-08-2015, 10:43 PM
huckster
huckster is offline
huckster is starting off with a positive reputation.
Unhappy 1999 5.4 f250 S/D
I'm at 225k as the 2nd owner. It's showing signs of loss in mpg and power. It may be decision time soon.$$$
  #178
Old 08-02-2015, 01:38 PM
raf2330
raf2330 is offline
raf2330 is starting off with a positive reputation.
2008 F150 4.6
280,000 mi. + on this truck, original motor & trans., still runs smooth. 2nd owner. Oil change every 5000 or under.
  #179
Old 09-03-2015, 02:21 PM
joe28540
joe28540 is offline
joe28540 is starting off with a positive reputation.
I thought it was time for a high mileage update. My old girl "04 FX4" is now 487,000 miles young. I want to get her up to at least 500K.
  #180
Old 09-05-2015, 02:59 PM
Ryan Donahue
Ryan Donahue is offline
Ryan Donahue is starting off with a positive reputation.
~155,000 miles
2003 expedition 5.4L 2valve 4WD
Reliable, and hard working, still runs like new.
Oil changes every 5k miles and kept up with other recommended service intervals
Never had any problems relating to the engine
Quick Reply: How many Miles are on your 4.6/5.4 Modular Engine ?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
