1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Engine oil
Old 06-19-2012, 06:44 AM
Strokin F250's Avatar
Strokin F250
Strokin F250 is offline
Engine oil
Whats the best oil to run in the 6.0 engine? What brand do y'all use?
Old 06-19-2012, 06:59 AM
Smokeispower's Avatar
Smokeispower
Smokeispower is offline
Do a search, there's more discussion on this than anything else (well maybe except for how do my ESOF hubs work). The oil definitely needs to be changed regularly, and it must meet the requirements Ford put in the owner's handbook, after that it's your choice. Rotella synthetic worked well for me.
Old 06-19-2012, 07:15 AM
Strokin F250
Thanks. I've noticed my turbo takes longer to spool lately. I'm using royal purple right know. The truck sits all week tho. But even after a trip to town it seems like its taking longer to spool. I'm wondering if the oil is part of the problem.
Old 06-19-2012, 07:51 AM
AGE mechanic's Avatar
AGE mechanic
AGE mechanic is offline
Amsoil 5W-40 works for me.
Old 06-19-2012, 09:03 AM
sammy77's Avatar
sammy77
sammy77 is offline
You'll get a lot of opinions on the subject. In general, 5w-40 is good year round, I'd suggest a synthetic over a conventional and more importantly, change it every 5k miles.
Old 07-03-2012, 01:18 PM
njjeeper's Avatar
njjeeper
njjeeper is offline
15-40 Delvac...on sale at WalMart right now!
Old 07-03-2012, 04:32 PM
AGE mechanic
We dont shop at Walmart on this site.
Old 07-03-2012, 04:41 PM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
Mobil 1, Shell Rotella Synthetic, Schaffer semi synthetic is high end oil I have used in equipment for years. Currently I’m just running Mobil 1 in my 08 5.4. If you’re going to run dino juice I use Rotella T 15W40 which is diesel engine oil. I use this in the 68, 442 along with ProLong additive. Took it apart after 40K hard miles the journals looked new.
Old 07-03-2012, 05:40 PM
Strokin F250
Thats whats up! Thanks for the info!!
Old 07-03-2012, 06:19 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
Just to answer the question, not to hear "opinions" I was doing oil test at each change for last 6 times. Mobil 1 generate high iron, what Mobil representative chose not to address on the net chat room.
Had no access to Amsoil, but Shell Rotella even in dino version was excellent, I settled to T6 after all this.
Old 07-03-2012, 06:32 PM
Strokin F250
What is T6. So far no one has mentioned motor craft. Why is that I wonder?
Old 07-03-2012, 07:01 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
T6 is synthetic Rotella and I am not the only 1 posting good reviews about it. My tests shows the dino Rotella and synthetic having basically close results, but synthetic give you extra protection and you never know when you can use it. Just a month ago oil pump got jammed on our Mercedes so it run for few minutes with no oil pressure. Yet after fixing the pump the 291,000 miles engine runs perfect. I prize synthetic for it.
I did test Motorcraft after 5000. The results were worse than Rotella dino after 10,000
Old 07-03-2012, 07:26 PM
Strokin F250
Woooow cool. Thanks! That's great to know. So is there a filter of choise?
Old 07-03-2012, 09:19 PM
TrdLtly's Avatar
TrdLtly
TrdLtly is offline
TreadLightly
While your at Wally World getting your Rotella T6 you may as well pick up your Motorcraft FL2016 (filter)
Old 07-03-2012, 09:35 PM
Strokin F250
Yea I have been buying filters on eBay. I get enough to change all filters 3 time for around $60.
Quick Reply: Engine oil
