Not a tech; but if its leaking have a local radiator shop fix it; also can't tell by the pic beyond it being a 65 TA number; I would say its a oem style rad; also you should have what I call a block off plate if its a 6 cid radiator verses a v-8. As I mention I can't tell from you pic.
No, not leaking. My truck runs a little hot, and I'm trying to decide what to do. I was just making sure this is the original and see if the oxidation on it or whatever was normal or a problem.
Thanks.
water pump? does the temp increase while sitting still, then drop back down when you're on the road?
Note: 1965 F100/250 352 2WD, 1966 F100 352 4WD radiator is not only different, but does not have these same applications. Does not fit 1966, because the flanges are in a different location.
1966 F100/250 2WD 352 radiator will not fit 1965's, different flanges, different radiator support than 1965.
