I want some help & advice about the 1973-1979 trucks.
#76
Thanks for the help montana_highboy. I was thinking about texting the owner to see if I can go see it. I was thinking about offering $1000 mostly because it will take 10 to 12 gallons of gas (assuming I get 10 mpg) to get back to where I live & I'll still have cash leftover for the tax, tag, title, & maybe the registration.
#78
#79
10 years ? Ain't that too long to search for a GTO ? That sounds (not to be sounding mean) a little ridiculous to me. I really don't want to be still looking for a truck that meets my "standards" for 10 years. I've been searching craigslist for the past 10 months & looking in the Indiana Auto & RV Shopper for the past month & a half. It seems to me like the number of Pre-EFI Gas & Diesel 4x4 trucks are dwindling. I certainly don't have the resources to find & buy a truck outside a 75 mile radius of a major city that I live at in Northwest Indiana.
Nope....I found the exact one I would have ordered. HO engine hidden headlights, electric antennae, 4 speed etc....Restoring a vehicle is BIG bucks....why not spend that dough on something you want? I understand your local 75 mile rule....but in the long run it will be cheaper to buy a western rot free truck than one that is local but has hidden rust damage. Good luck with the search.
#80
#81
Ok, once a again I was trolling a local craigslist the other day & found this...
1977 ford f250
I've been floating on about rather I want this truck or not. I do know that the 460 didn't come in dent 4x4's. But, my question is now... should I consider this truck in my search or not & what should the price be if you don't think it is worth $1400 (which I personally don't think so) ?
1977 ford f250
#82
1977 ford f250
1977 ford f250
#83
Well, I was trolling craigslist yesturday & found this...
1978 F250 Ranger XLT
I talked to the owner of this beast & there are 3 problems with the truck:
- Power Brake Booster is going out
- The truck's steering column is loose (might need a new one)
- It needs a new header on one side of the block because the collector has rusted out
I'm planning on looking at this truck on sunday afternoon.
So... what do you think ?
#85
I need help turning an old truck into a welding rig work horse
I have a 1977 ford f150 4x4 long box? to make a long story short I worked at a refinery as a welder helper during there turn around and the welder I worked with didnt have a dually for a welding rig it was a dodge mega cab cummins diesel and he said the tires were rated for the load and he had 1 ton suspension ? I was wondering how I can apply this concept to my old truck? what kind of lift or suspension to suppot the load of a welder and if turning my 351M into a 408 stroker would be good or bad to my build ? also what gear ratio would I need to pull the weight? thanks for any help possible
#86
#89
CarexGrayi
04-16-2015 05:56 PM
onthefloor
12-05-2002 06:35 AM
