Ever seen a 3bbl carb???
I didn't know they made them until I was looking at fleabay and saw this:
1983 Ford 7.5L 460 V8 OHV Van Truck w/ auto trans 3 BBL Carburetor 40-807 REMAN | eBay
I thought the 460's came with 4 bbls?
I don't know what the heck that thing is...
But I've seen a 3bbl carb. Back before the Dominator was big Holley, and probably others, played around with 3bbl carbs. They looked similar to 4bbls but the secondaries I believe were cut out and made into one large oval bore with an oval butterfly in them. They were like 900 or 1000 cfm. Dominators just worked better and that was the end of them.
Google Holley 3 barrel carb.
I don't really know. I don't know anything about running a vehicle on propane either.
Do propane carburetors have fuel bowls? Common sense and thought says no. It appears that that carburetor doesn't have fuel bowls, and just has fittings for a vacuum line? Look at the bowl vents at the top of the venturi and where they run. It might be for propane.
I saw in the last picture that the carburetor was re-manufactured by US Carburetor Co. of Rosemead, California. I tried looking up the company and from what I saw, it's closed down.
If it's re-manufactured, who manufactured it?
Typing 40-807 into the search bar doesn't make for much either...
i cant see any fuel bowls either , iave seen some 460 engines run on propane fro generators !
also cant find any info on US carbs
Just got reading the online article that that above picture came from.
The Honda 3bbl Carburetor came on 1st generation Preludes that had the 1.8L inline-4.
Carburetor Factory - Keihin 3 BBL Exploded View
Turns out it's called the Keihin 3-bbl.
Something interesting that I saw was that Hitachi actually made carburetors. Hitachi are known in this day and age for their electronics like hard disks.
Now I need to see if i can find out what the tiny venturi is for.
