before i give up i want your opinion....
03-03-2012, 09:02 PM
Meaning you could have more fuel that could be burnt at idle. A buzz test only test the electrical parts you need to have a CCT (cylinder contribution test) done to see if the injectors are dumping the right amount of fuel
03-03-2012, 09:05 PM
You have two plugs going to each valve cover. Unplug on plug at a time and start the truck and see if if stops smoking.
03-03-2012, 09:11 PM
I would try the white smoke sticky thread at the top of this forum and go through it. Might be a lot easier...
03-03-2012, 09:15 PM
on
Quote:
Originally Posted by
fordpride
I will try this tomorrow. Do you know if the harbor freight scanner will check this?
03-03-2012, 09:16 PM
on
matowns21
This being the cylinder contribution test. Sorry.
03-03-2012, 09:23 PM
on
Rick, does a person need a special scanner to check the IPR DC % or could someone take it to an Oreilly's and use there scanner for free?
03-03-2012, 09:33 PM
matowns21
You'll need something lime a AE,'snap on, OTC, or a scangauge
03-03-2012, 09:34 PM
Action4478
Have the truck scanned , look at the IPR DC% ,,(sticky IPR is my wag )...
Whats the DC% mean?
03-03-2012, 09:35 PM
Iallwork
The part store scanners won't read a psd. A good shop will have one that can see live data
03-03-2012, 09:36 PM
on
03-03-2012, 09:38 PM
jiveturkey692000
Whats the DC% mean?
It's the IPR duty cycle which is the percentage that it is closed. For exp. if you have 15%DC then the IPR is 15% closed
03-03-2012, 09:43 PM
fordpride
Thanks
03-03-2012, 09:57 PM
on
fordpride
What % range should it be?
03-03-2012, 10:13 PM
Depends on your throttle position, mine will vary from 13% at idle to 45% WOT.
03-03-2012, 10:16 PM
