2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Double DIN Dash Kit?
Old 02-26-2012, 01:06 PM
killalldude's Avatar
killalldude
killalldude is offline
Hello fellow Ford Owners!
I'm new to these forums, about 10 months ago I picked up a 2008 Lincoln Navigator with 28,XXX miles on it. It had practically whatever I wanted except navigation.
This weekend I installed a new headunit which has navigation. It is a Pioneer X710-BT. It replaced the factory 6-disk CD changer. I had to cut the bezel to make it fit:
I cut the small bar at the top. I mounted the headunit using the mounting brackets from the stock headunit, and this is how it lines up:
The top and the sides are flush with the bezel, however there is a 1/2" gap at the bottom. Anybody know which dash trim kit that will be compatible with this?
All help is very much appreciated!
Old 02-26-2012, 06:14 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
The only kits I've seen for Navigators are ones that already have factory navigation. The radio bezel surround is different with factory navigation, the opening is bigger. You could try one of those kits and just trim some more of your bezel opening, or buy a whole new radio bezel = $$$$
Here is an example of the kit:
http://www.crutchfield.com/p_1209558...t.html?tp=3121
Matt
Old 02-27-2012, 08:18 PM
TFWcustoms's Avatar
TFWcustoms
TFWcustoms is offline
Check with online junkyard, I was going to do the same exact project and i was able to find the part for 150. Another option is to just glass in that section and then repaint the panel
Old 02-28-2012, 06:31 PM
killalldude
Thanks for the help guys. Unfortunately, the OEM Navigator navigation bezel is nearly impossible to find. I'm most probably going to have someone fiberglass and paint it for me, as I have no skill with fiberglassing.
Old 03-01-2012, 09:12 PM
07xpyebel's Avatar
07xpyebel
07xpyebel is offline
This may help you.
METRA 95-5812 2008 LINCOLN NAVIGATOR AUDIO DASH KIT RADIO INSTALLATION STEREO
GGerald
05-18-2020 04:50 AM
Tuquala
01-10-2015 01:54 PM
xmontex4
1999 to 2016 Super Duty
01-01-2011 12:33 PM
toddn78
11-07-2005 10:06 AM
BIGRNU
09-09-2005 06:47 PM
Quick Reply: Double DIN Dash Kit?
