Loss of power
Loss of power
2004 f250 6.0. When trying to climb hill tried to kick it to passing gear and it had no power felt like the Turbo wasn't working. Then it kicked in and heard the Turbo. Ran ok for awhile then did it again. Changed fuel filters ran good for awhile. Now its back to it again. Any ideas? No check engine light on. Its like I have no Turbo. Need help I'm 500 miles from home.
It sounds like the turbo vanes are sticking and your turbo needs cleaned. You might take it out and run it HARD for a bit to see if that helps clean it out. The other alternative is removing the turbo and cleaning it yourself or visiting a shop. There are good instructions in the 6.0 tech folder at the beginning of this forum.
took the truck to the ford lot and this is what they had to say
1. turbo sticking
2. needs new egr value
3. icp showing readings not consistant
4. ficm throwing multiple sensors
5. deguas bottle swollen..
6. possible blown headgasket.
they shot me a price of $9670.00 WOW a truck with 171k miles
1. turbo sticking
1. turbo sticking
1. turbo sticking
Boy I would say WOW 10K Huh
Has it been Puking coolant does the heater blow heat at Idel does it have temp spikes these are sign of bad HG
Do you run a Tunner
First time Iv ever heard a Swollen Degass bottle
do you know what codes they pulled
I dont believe the HG is blown, temp always stays normal no spikes what so ever. No water in oil The degass bottle has white specs on it and is swelled up and thats why they think HG. Truck runs Great expect recently the turbo started sticking. The codes they showed me where from the EGR valve. I unplugged it hoping that was the issue. But from Missouri to Oklahoma it stuck once. Had no power then I kicked it down. If I let off of it and back on ran good again. So im believe it's just the turbo sticking and EGR valve. Then they said the ICP reading was flucuating. Yeah I think that quote was for a new turbo, egr, HG labor and all. I don't have any guages or anything.
I'm planing on have the turbo veins cleaned from ford they qouted me $467.00 But whats the price of a new Turbo? If it's not to much differnt I'd just put a new turbo in it.
Dont think the turbo is sticking? I Dont have boost till about 2300 rpm. but then at times trying to climb a hill its like weak dropped to 60mph rpm to 3500 and no boost then it finally kicked in. I unplugged the EGR valve would that not take care of that or would I need to replace it?
Go to an auto parts store and scan it for codes
Unplugging the EGR Valve maynot help if its all gummed up and stuck open
If you ever pass an AutoZone stop in get the Codes read and see if they have a ScanGaugeII you could buy you can program it to read alot of stuff on this 6.0 Like Boost,EBP,MAP,VGT those are the sensors the PCM Reads info from and also uses to control the Turbo.
Also check the CAC Boots for leaks
are you losing any coolant
If you can post a pic of that Bloated coolant bottle. I have never seen or heard of that B4. Usually they Crack on the seam.
Might also be worth trying a new Coolant bottle cap to its cheap. Usually they get weaker over time and wont hold pressure so IDK but couldnt hurt to try it.
IMO it would take ALOT of pressure in the coolant system to Bloat the coolant bottle.
A Blown EGR Cooler will put pressure into the Coolant system to. If it were me Id pull the EGR Valve clean/replace, and also look into the EGR Valve chamber in the intake manafold and check for coolant there.
No Boost Might be from a Bad sensor or turbo bad or a CAC leak. It would be worth checking the sensors I mentioned B4 before you replace the turbo. Some of those sensors could also be affecting EGR Valve operation
It would be in your best interest to get a ScanGaugeII and start checking the truck out
Do you run a Tunner
Do you run a Tunner
Do you run a Tunner
Do you run a Tunner
No tunner truck is bone stock. has never even pulled anything before. Heat does work at idle. Ordered a scangauge 2 gonna take 2 days for it to get here. Driving back to texas Tuesday will see how it goes. Did alright around town today of course I didn't get on it to much. Went from Texas to missouri then to Oklahoma hasn't used any coolant. So I dont believe its the HG.
