460 EFI Cal Timing cover locate or repair advice...
Hey guys, I'm having trouble locating a good timing cover. Mine has the mounts for the misfire sensor, and I can't locate one anywhere. Next question would be....has anyone ever tried to repair one? Either by welding or a good aluminum epoxy? Also, Isn't there supposed to be an oil deflector behind the seal???
Thanks!
Al
Thanks!
Al
Summit Racing has one for mine....
Dorman 635-101 - Dorman Timing Chain Covers - Application - SummitRacing.com
I do appreciate the link, but unfortunately, I can't use that type. Mine has the mounts for the "misfire" sensor cast into it. I don't know how realistic it would be to try and weld those mounts onto a new cover. My truck is a California truck, and has a "trigger wheel" just behind the balancer, and there is a sensor mounted about where the pointer would be on most timing covers. And I can't find one anywhere. I have mine off, I guess I'll bead blast it tonight, and see how it would be to try and repair it.
No worries, I truly appreciate your input. But yes, it seems many things I've gotten involved in don't have a simply solution....lol, but I'm getting used to it. I started cleaning it up last night, and got a little bead (glass) blasting done as well. I think I may use DuraBond to repair it. I've read some on it, and it seems to be a realistic option to welding, might even be a better solution. I talked to a friend over at ford, he couldn't find it quickly, so I told him I'd get the engineering number from it and see if that helps. But I'm scared it's going to be a million dollars since it was a very limited production run, if it's available at all. So I've pretty much resigned to repairing this one.
Obsolete Timing Cover
Just went through the same problem ended up welding it. It worked out well.
The article below sums it up and is also what I found out. Ford Parts Department lists it, $350+ but can't find it in any warehouse.
Obsolete 1997 Ford 7.5L 460 V-8 Timing Cover
Read more: Obsolete 1997 Ford 7.5L 460 V-8 Timing Cover | Editorials Blog & Discussion at 4 Wheel Drive Magazine
otis348
03-10-2019 07:20 PM
Aquatrojan
04-03-2010 02:16 AM
79CuZTuM
13
09-17-2008 07:27 PM
jlanza
12-13-2007 07:32 PM
