General Upgrade Thread (Formerly D50 rebuild) Pic Heavy - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 04-17-2012, 09:26 PM
tecgod13 tecgod13 is offline
tecgod13 has a good reputation on FTE.tecgod13 has a good reputation on FTE.
We just had a thread a few weeks or month ago going through some axle ratio stuff. The difference in sizes between the ring gears means you can't always get the same ratios for different axles. 4.10 vs 4.11 is fine, its not enough of a difference to really matter.
  #32
Old 04-17-2012, 09:30 PM
SnuffthePunkz's Avatar
SnuffthePunkz SnuffthePunkz is offline
SnuffthePunkz is starting off with a positive reputation.
So 4.10 and 4.10:1 should be fine then. Just wanted to double check before I installed them all.
embed test f350ktm Testing..... 7 01-20-2018 06:30 PM
2017 1ton towing comp sam hain 6.7L Power Stroke Diesel 8 03-20-2017 03:16 PM
Roof center console? SnuffthePunkz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 04-16-2014 07:54 PM
New Trans - Solenoid firing continually in engine bay With Video SnuffthePunkz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 08-25-2013 02:05 AM
Photo - is this 3G alternator commutator excessively artfd 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-25-2012 09:48 PM
Tags
1025, 1990, 50, 92, blue, bronco, dana, f250, ford, hubcap, hubcaps, lost, matte, paint, rebuild, sterling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
