I slacked a bit this time and got my sample in a while after my oil change.. In any event, here are the stats. Aluminum looks a bit high. Any comments from some of the resident experts (vlony, pbruckne, etc)?
I've noticed most of us use a company called Blackstone Labs.
You send it via USPS or UPS, etc. using their container so it doesn't have to be local.
I usually use UPS and throw the container in a small box. Easier for me to ship it at work.
My last report showed Aluminum at 21 which they said was not a problem, they also noted that aluminum wear should read about 33% of iron wear. I have switched to Rotella 5w-40 since the last report. My 6.0 typically shows aluminum at 3 and I have been using the Rotella in it for more then 3 years.
Every engine wears different.... I believe your aluminum hit the radar because of the upward trend. I would run your current Motorcraft (assuming this is your current oil) another OCI and if the trend continues, then I would try another brand of oil and go from there. Keep in mind driving style, pulling heavy loads can affect wear metals as well.
I like the report idea, how would I find someone in Phoenix to do this?
Fingers crossed on the aluminum deal though....
You can go to Blackstone's website and order free oil sample bottles. Quite a few people on this site, including me, use this lab for testing. I do not know of any local to your area.
I used Blackstone when I had my 6.4 after some recommendations here on FTE. Its a mail-order test, you can send in a sample from anywhere. $25 for a regular test. There is another test that you can have done, but I think its another $10 or so (I don't have a sheet in front of me to reference).
