Difference in 2010 Fuel Mileage
Ok haven't been on here in a long time. But my dad and I just recently bought used 2010 F150, he bought a XLT crewcab 6.5 box with the 5.4 and 3.73 gears he has roughly 15k miles on his and I have a Platinum crewcab 6.5 box with the 5.4 and 3.73 gears and roughly 26k miles on mine. We both were coming back from upnorth, highway driving, both had the cruise set at 70mph and he even called me to ask what I was running for RPM and it was the same. He said he was getting 16.9 and I was at 13.8. I filled up earlier and calculated out my MPG and the computer was pretty dang close. So my question is why such a big difference, one thing I came up with would be he has the stock 18" wheel where I have the stock 20" wheels. I would like the experience of everyone out there. We are both scratching our heads to why there is such a big difference.
There must be something else going on I would say, very hard to say what that could be, as a ton of factors can have an effect on gas mileage.
i remember my grandfather telling me a story about him and his brother going somewhere in a motor home once. It was his brother's motorhome, and he was always confused as to how my grandfather was able to get better mileage driving than he did.
my grandfather claimed that his brother stepped into it much harder getting up to speed, instead of using a lighter foot and taking longer to gain speed.
on a long trip using cruise conroll, you would think that it would eliminate the driver, for the most part at least.
perhaps the cruise control is set more aggressivly in the truck getting lower mileage?
that's a pretty big spread for "the same truck"
I'm not a huge fan of CC as a gas savings measure. It's no different than mashing down on the pedal and then letting off the pedal all the time. To me it's good when your foot needs a rest and when you're in a known speed trap.
The Plat may be a bit heavier and it may draw more power to keep the electrical load satisfied.
I think you have to start off the same way. Check tire pressures and ensure that each tire is aired up as per Ford's recommendations. Ensure that each truck has a similar amount of weight, ie, passengers, gear, etc. Get underway at the same time and remain in the same lanes.
Then again, we could all be waaay over thinking this.
gopedoligist
6.7L Power Stroke Diesel
32
03-14-2013 08:49 AM
hoxiii
03-21-2005 07:48 AM
