1989 F150 dies when switch is "on"
Old 02-23-2012, 08:06 AM
Ronvic's Avatar
Ronvic
Ronvic is offline
My 89 F 150 dies (loses all electrical power) when the key is turned to the on position. The battery is fine. It has a new solenoid switch. If I connect a battery charger to boost the power the fuel pump will respond. Sometimes normally (run for a few seconds then stop), sometimes it will continue running, other times with the switch "on" I can honk the horn and the fuel pump will re-engage. If I disconnect the battery charger and turn the switch "on" I can hear a light buzzing sound. I can feel a click or vibration in the fuel relay. What gives? do I have a bad fuel pump relay? Would this keep the engine/starter from even turning over?
Old 02-23-2012, 08:09 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
It sounds like you have some seriously corroded battery cable connections..
Clean all the cable connections (both ends) , and if you have the "clamp on" cable ends at the battery be sure to take them apart and clean there too..
Welcome to FTE
Randalll
06-05-2016 09:23 PM
bcrone821
17
06-10-2015 01:55 AM
knuck
1947 and Older Ford Trucks
08-18-2007 11:01 AM
hagg26
09-16-2005 05:25 AM
Snowman4x4
Electrical Systems/Wiring
08-20-2002 08:50 PM
Quick Reply: 1989 F150 dies when switch is "on"
