Sharing my new $56 exhaust system
So a little while back, I decided that I wanted to change up the exhaust system on my '79. Having finished an engine swap in September, and getting everything running right, I was eager to try something.
Here's what I did:
Bought a 36" long by 4" diameter Heartthrob glasspack, with 2.5" in and out. Took the stock system apart after the 2-1 pipes off the manifolds, and cut the cat off, and removed all the pipes. The pipes were in good condition, so I saw no reason to replace them (I was also on a budget). Cut up the old system to get the parts of the pipe I needed, and went to work.
Pipe between the muffler and 2-1 pipe came from in between the stock muffler and cat.
Chunk coming out of the muffler was cut from the stock out to the axle arch.
Then took the axle arch, did some trimming, and put it on using a coupler. I know it's not the best for flow, but it's what I had.
Cost Breakdown
Muffler: $45
Coupler and 2 u bolts: $5
Exhaust tip (not shown in pictures): $6
Here is the sound
In Cab and out of '79 F250 w/glasspack - YouTube
1979 F250 New Exhaust - YouTube
Here's what I did:
Cost Breakdown
Muffler: $45
Here is the sound
