1st Blackstone Oil Analysis
I have one installed on my truck now.. had one on my last one.. and i have them installed on my dads diesel suburban.. and my moms silverado.. they're great!
My truck has a three year history of oil dilution. From 2% to 6%. I deleted 6500 miles ago. When I deleted I changed oil and filter. At 5000 miles I changed oil and filter again and got a blackstone report. It was perfect, less than .05 dilution. I can't tell y'all how disappointed I would have been to still have diluted oil.
If the OP had a complete oil change including a new filter then perhaps his short trip driving is causing dilution. However, I drove my 7.3L on many short trips and never experienced dilution. OP, are you sure oil and filter were changed after the deletion?
According to the EPA ULSD will "boil" out of the oil like water will. So even if the OP is driving short trips he must make some trips where the truck works hard, during those times the dilution should at least be lowered. That does not apply if he is using bio. The bio will not boil out. Again that's according to the EPA. So OP, are you using bio-diesel?
It just doesn't make sense to me that enough diesel would seep into the oil of a deleted truck to cause 2% dilution. I'm not hearing from anyone else who has a deleted truck about dilution and I've read most every thread on here for the past three years and on the 7.3 forum for 7 years before that. I get what Sennix says about the top ring expanding, but there are several (I guess) other rings on there, at least one of which should be designed to hold and wipe the seepage. The dilution on these trucks is caused by the DPF technology. According to the EPA all diesels using the exhaust stroke burn technology experience some level of dilution. I don't believe that is a problem for diesels not using DPF technology. How about the 6.0, do they experience dilution? The 7.3 didn't.
If I were the OP I think I would drive through one more oil change and make sure it's a good one and get another blackstone. Of course, what else can he do, walk to work?
i'm not using Bio unless the exxon down the street from my house is using it.. lol
i have never used bio intentionally, i get my fuel from the same 3 fuel stations near my house, unless i'm traveling, then i really dont have a choice.
I'm going to do another 5k change as soon as i'm due for a change.. i have 3K left before my next change, and i'm interested to see what it will be like this time.. i always change the filter when i change my oil.. but you guys aren't going to believe this.. the last time i changed oil, (the one before the report) i started draining my oil in the driveway, then drove down the the local advance auto parts for an OEM motorcraft filter, which they usually always have.. this particular day, they didn't have one.. so i was kinda screwed at this point and had to get my truck back up and running so i put the new oil in and said to myself... " I'll go to the dealer/parts store down the road a bit tomorrow. and because i'm a huge dummy and have the worst short term memory, i forgot to get another oil filter.. so on the last oil/filter change i just did and got the oil analysis done, that could be a factor in the dilution.. cuz when i took the filter out.. it just didn't look right, i looked at it and it looked funny.. and i thought to myself.. "i'm an idiot!!!!!" and remembered i forgot to replace the filter.. so i had 5K on the oil.. 10K on the filter on the oil analysis.. stupid me. i still dont know how that would affect the 3% fuel dilution..
would cycling the fuel pump with the ignition a bunch of times have any effect on fuel seeping past the rings?? i did retune my truck probably 5 or 6 times in that 5k mile period trying different tunes on my LiveWire. just a thought..
Because our trucks and dilution history are so similar I just thought there must be some unusual reason for your report. First thing that came to mind was an incomplete oil change with some diluted oil left in the engine. Absent that, or a lot of bio use I don't have a clue. Sennix is on top of this stuff so if the dilution continues on your next change I guess it's your short trips. It's just very hard for me to imagine 10 ounces of fuel seeping past the rings on any internal combustion engine that isn't worn out. Let us know. I have an oil maintainence program that worked for me when the DPF was still on. If your diluution doesn't clear next change i'll share it with you. Please let us know how you make out.
Are you deleted. If so, then the EPA report would not apply to you, neither did it apply to the 6.0 or 7.3. The report addressed the impact of oil dilution on DPF technology. The DPF technology causes the dilution. It stated that to some extent the diesel will "boil" out of the hot oil. Bio will not boil out, at least not as well as ULSD. This current thread not withstanding, there should be very little dilution in a non DPF engine. Until convinced otherwise I remain skeptical that 10 ounces (2% dilution +/-) of diesel fuel could seep past the rings and down the cylinder walls of an engine in 5000 miles. If anyone else who has a deleted DPF is still having dilution problems maybe they could chime in here.
It is not the DPF technology it is the way Navistar designed it (to shoot Fuel into the cylinders, then through the valves, then the turbo only to then hit the DPF) and not directly into the DPF with a 9th injector like Duramax did. The explanation for doing it the way Navistar did can only be cost. When Ford designed the 6.7 why in the world would they continue this idiotic approach? even if they get less dilution it still can not be good on any of the components passing raw fuel. I think (hope) it is raw fuel untill it reaches the DPF then ignites?
#28
https://www.ford-trucks.com/forums/p...ictureid=93827
Last 5 oil reports - 08 F25- PSD 63,000 miles on it - 8,000 on last oil change of which 3,000 were pulling our 9,000 lb 5er the harder you work these trucks the higher the exhaust temps and less regens - resulting in less fuel dilution. Sept warranty is gone and so is the DPF
#29
#30
