How to ID the heavy duty 300 six - Page 2 - Ford Truck Enthusiasts Forums
Old 06-07-2018, 04:02 PM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
AbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to all
Originally Posted by 1986F150six View Post
I have wondered why Ford did that [open heat riser] on the HD engine? The only thing that makes sense to me is that these engines were made to run @ 3,000+ RPMs and maybe [?] the temperature was kept at a minimum with the extra exhaust gas flow.
I've often wondered that too. You'd think it'd be even hotter running at higher RPMs.
Even if not, they weren't all going to be operating at high RPM all the time. There's stop and go situations in ANY application.
Old 06-07-2018, 05:16 PM
fordman75
fordman75 is offline
fordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to beholdfordman75 is a splendid one to behold
Maybe they want it to run hot enough to vaporize the fuel. With the low compression maybe it needed all the help it could get. Who knows, I'm not an engineer.
Old 06-10-2018, 09:44 AM
worldchampgramp2
worldchampgramp2 is offline
worldchampgramp2 is starting off with a positive reputation.
Thumbs up True Find
Originally Posted by applebaggins View Post
They mention the crank a little earlier... shown below...
Bless You exactly what "Gramps" has been searching for. Can you please respond with the exact Ford publication title/date this info came from? I need to acquire a personal copy for our very extensive cylinder head Development Dyno program.
Many Thanks, Bruce Sizemore
Old 06-11-2018, 07:51 AM
applebaggins
applebaggins is offline
applebaggins is starting off with a positive reputation.
Hi, Gramps. This is from the 1978 Truck Shop Manual. It's a five-volume set, but this is from volume two. Here's an extract of the 4.9L 300 section. You won't be able to search the text, but it should still be readable. https://ufile.io/h1r9k Just a warning, that link is only good for 30 days!
1986F150six
12-12-2017 04:23 PM
brian.b
09-23-2016 09:06 PM
Funke1
1968-2013 Full Size Vans
07-28-2015 02:41 AM
bmwcarl
07-03-2015 06:35 PM
jp1251
Vehicles for Sale
06-14-2015 05:47 PM
Quick Reply: How to ID the heavy duty 300 six
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
