1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2003 f350 parking assist inop.
Old 02-20-2012, 05:53 PM
chilliboy93's Avatar
chilliboy93
chilliboy93 is offline
Exclamation 2003 f350 parking assist inop.
hello im new to this so be patient with me i got a 2003 f350 lariat with parking assist sensors. when i put the shifter in reverse the light on the button to turn the sensors off says that they are off even tho they are supposed to be on automatically. well anyway ill press the button thinking it will turn them on and the light with flash off and then turn right back on immediatly. but when i put the shifter into park or drive the light with turn off as it is supposed to be. i asked a tech at the dealer i bought it from and he says its the reverse module. but i feel that that isnt it because i also have a back up camera and when i put my shifter in reverse it works just fine.?.? also i read other threads and they were talking about the pam well i located the pam and felt to see if the harness was plugged in and it was. i also unplugged each sensor and checked the connection and they all seemed perfectly fine. so can ya guys help me out?? any help or ideas are very appretiated thanks.
Old 08-10-2012, 09:32 AM
NFC002's Avatar
NFC002
NFC002 is offline
check this
sorry just found this post
to check the sensors turn key on ,park brake ,put in reverse,go listen to each sensor they should hum ,listen good,if not its no good and the system will turn off
hope this will narrow it down
pokeycameron
01-02-2014 08:39 PM
rattleNsmoke
05-22-2013 09:30 PM
Ironhide
12-24-2012 05:01 PM
kingair41
05-21-2012 07:47 PM
Powerstrokin_350
04-17-2012 07:48 AM
Quick Reply: 2003 f350 parking assist inop.
