Sponsored by: Real Truck
Pickup bed swap??
Old Feb 20, 2012 | 01:00 PM
omegapi103's Avatar
omegapi103
Pickup bed swap??
Please anyone..can i swap an 2011 6ft pick up bed onto an 2002 f250?? i can see that the cab "lines" and the outside "bed lines" match up correctly, just not sure of the underside and bottom of new bed..thanx in advance....Rob
Old Feb 20, 2012 | 01:34 PM
Sarge261's Avatar
Sarge261
I am pretty sure that it can be done, the only difference will be the rear wheel well contour is different that the front wheel wells'. Remeber to buy new hardware, bolts and frame nuts, as you will most likely need to cut them off.
The was a guy on here who did it and it didnt look all that bad, but the body lines were noticably different.
Sarge
Old Feb 20, 2012 | 03:13 PM
Onsight's Avatar
Onsight
Keep in mind that if the 2011 was a diesel, the fuel door will be bigger. I put a box from a 2012 onto a 2010 chassis and it fit great, just had to adjust the fuel filler neck.
Tyler Drysdale
Apr 15, 2019 07:22 AM
MisterCMK
Jul 20, 2017 10:38 PM
omegapi103
2009 - 2014 F150
Feb 20, 2012 02:22 PM
Gman91
Feb 7, 2008 07:46 PM
emgee
Jul 22, 2007 10:33 PM
