Ford manual 4x4 transmission id HELP PLEASE!
Here is a pic of the ford manual 4x4 transmission that I'm trying to id. I'm posting in this section because I don't have a clue where to post. Any help would be much appreciated. I'm hoping its a 5 speed that would handle a 4bt cummins for a new project. I will try to get some numbers up soon. I have researched the hell out of this and can't find anything. The transfer case is a new process 208f.
Thanks for the link dude. Believe me, I have several times. Seems to be a not so common transmission. Od sounds good, but a comment was made about not so tough. Wonder if a 4bt is too much torque? Will continue to research.. if anyone has ever tried this combo, please let me know your results.
This trans is a modification of the RUG SR-OD 4 speed, originally designed for Granada's and Fairmonts with I-6's and 302's.
Ford began installing this trans in F100/150 & E150's in 1978 in an effort to improve fuel economy...which became an important issue for the very first time...during the first Arab Oil Embargo that occurred 1973/74.
The second Arab Oil Embargo occurred in 1979. A gallon of regular jumped to a buck from 20-25 cents after the first embargo ended, jumped to a buck 25 after the second ended.
The prices look cheap, don't they. But, they aren't cheap, because back then, a buck was worth far more than it is today.
51MHF5
17
10-03-2019 06:41 PM
mudding4life
07-28-2006 05:19 PM
Tom Cat
11-09-2003 09:38 PM
