transmission temp sensor
Old 02-19-2012, 05:35 PM
Lance4986's Avatar
Lance4986
Lance4986 is offline
2005 f-250
tow/haul light flashing and check trans temp shows up on display.
transmission goes into limp mode shifts really bad and also throws its self in and outta gear
im guessing my temp sensor has gone bad. should i change the sensor and the internal harness?
am i on the right track to fixing the problem or am i completley wrong
Old 02-19-2012, 05:49 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
You're most likely right. I recommend changing both the sensor and the internal harness. 90% of the time it's the sensor, but it should would be annoying if it were the harness this time!
Old 02-19-2012, 06:06 PM
69cj's Avatar
69cj
69cj is offline
What is the service history on the tranny? Type of fluid, mileage on changes, flushes, external filter change etc.
Old 02-19-2012, 06:41 PM
Lance4986's Avatar
Lance4986
i have around 90k ont the and the transmission was rebuilt around 50k
that was the last time the fluid and filter were changed
i use motorcraft mercron sp fluid
Old 02-19-2012, 09:51 PM
Randy777's Avatar
Randy777
Randy777 is offline
Rebuilt at 50,000! Do you tow super heavy? I thought these trannys were good to 150,000 plus.
Old 02-19-2012, 10:09 PM
Lance4986's Avatar
Lance4986
some how water got inside the transmission either from the coolant lines or maybe from launching boats. it was a big surprise to me aswell
Old 02-20-2012, 07:13 AM
Mark Kovalsky
These transmissions are good for 250,000+ miles if water doesn't get inside.
Old 02-20-2012, 08:20 AM
69cj's Avatar
69cj
69cj is offline
You are past due for a tranny flush and external filter change. Every 30,000 miles min.
Old 02-20-2012, 09:44 AM
Sark's Avatar
Sark
Sark is offline
Thumbs up
Some might say I service my tranny too often as I have the dealer do the flush every 15,000-18,000 miles.
I'd rather be safe than sorry as 60,000+ of the 80,000 miles on the trk have been towing our 1/5 whl trailer with a combined weight at 21,200lbs. which is a pinky over the max. gross for the trk.
If we didn't tow as much at the max. gross then I'd go with the recommended 30,000 change interval.
Old 02-20-2012, 12:24 PM
Lance4986's Avatar
Lance4986
Does any one have a picture of where the sensor is located so I'll know just what Im looking for when I go to change it
miked79928
1997 - 2003 F150
02-12-2018 07:59 PM
BLADE35
10-01-2013 01:18 PM
mustang9701
01-20-2013 08:25 PM
swampfire79
01-28-2012 04:17 PM
Phillip Vega
1999 to 2016 Super Duty
04-10-2011 05:36 AM
Quick Reply: transmission temp sensor
