460 fuel issue
Old Feb 19, 2012 | 04:40 PM
bmacky14's Avatar
bmacky14
Angry 460 fuel issue
i got a 81 ford motorhome with the 460 carbed it only starts if i poor some gas in the carb sounds like a fuel pump but i disconnected the fuel line before the carb and turned it over and it is pumping gas out so the fuel pump is working and its got a brand new fuel filter what could the problem be
Old Feb 19, 2012 | 06:44 PM
Franklin2's Avatar
Franklin2
Hook the fuel line back up, crank it a few times, and then take the plastic end of a good sized screwdriver and peck on the top front of the carb. That may jar loose the needle valve. I bet this thing has been sitting a little while correct?
Do you have a 4bbl holley/motorcraft carb on this engine?
Old Feb 19, 2012 | 08:37 PM
bmacky14's Avatar
bmacky14
Alright I'll try that tomorrow. Ya it is the 4 bbl motorcraft carb and it has been sitting for about a year but it was running on its own for about 20 minutes a week ago then it killed its self and now I can only start it by putting gas in the carb
BlueOval390
Jan 2, 2009 12:50 PM
JBradley500
Dec 16, 2006 04:51 PM
johnsf
Nov 1, 2005 07:43 AM
Shane269
31
Jul 21, 2005 09:29 AM
driftinggrifter2
Jun 29, 2005 04:18 AM
