1996 F250 HD: Turns over, but won't start, argh! - Page 2 - Ford Truck Enthusiasts Forums
Old 03-07-2012, 05:54 PM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Originally Posted by Bronkenstein View Post
yea its helping me get closer. thank you. I'm now at a no start status and code 211 is present....
The most likely cause for your issue is a bad PIP as well. Code 211 is telling you a good story here
Rockauto has a brand new Motorcraft DA2079 distributor for $91.
Old 03-07-2012, 06:24 PM
Bronkenstein
Bronkenstein is offline
Bronkenstein is starting off with a positive reputation.
ordered....
Old 09-22-2017, 03:28 PM
TRUST NO ONE
TRUST NO ONE is offline
TRUST NO ONE is starting off with a positive reputation.
I have the same problem 1994 f350 won't start turns over runs with ether I have spark I have fuel
1994 f350 won't run I have spark and fuel to the fuel rails will run under ether but not gas
Old 09-22-2017, 05:03 PM
joey2fords's Avatar
joey2fords
joey2fords is offline
joey2fords is gaining momentum as a positive member of FTE.joey2fords is gaining momentum as a positive member of FTE.
since you have spark, and it will run on ether, you should focus on the fuel system.
fuel spraying (or dribbling) out of the schraeder valve isn't good enough. you need to check fuel pressure with a gauge.
what engine do you have ?
Old 01-03-2018, 07:26 PM
Bill Wiggins
Bill Wiggins is offline
Bill Wiggins is starting off with a positive reputation.
96 f250 351w 5.8. Cranks no start. HELP
Originally Posted by Momba2 View Post
Got it fixed! It ended up being the pick up coil in the distributor. Replaced the whole dist. and cap et cetera.... That, with new plugs, wires, coil, ..... Man, it's running GREAT!
Thanks again for all your help, and hopefully this will help someone else! Mike.
If this pickup in the distributor was going bad would it cause truck to miss at idle horribly then get to the point I'm at now with cranking but just won't start. I replaced in tank fuel pump. Also replaced FpR have filter on way (won't fix problem coz old filter had zero sediment in it). Originally it was missing super bad one day to point of having to 2 foot it at a red light. I parked it and each time I'd start it it would idle worse and worse then wouldn't idle at all just dies. I had to flutter the pedal like a mad man just to get it to stay running to move it in the yard. until right before I changed fuel pump. Then it would crank fast and act like it wanted to start but just wouldn't fire. Or I could almost hear it trying to run like sht while cranking but if I let off key it wouldn't be running. Is it hard to change the pick up in the distr?? I can get the module for about 40$. I really thought fuel was problem since I had 3 old pumps in the truck when I bought it lol. Anyways I'd really appreciate the help here guys. I'm not a novice but don't keep up with all the abbreviations so......
87hambone3531
02-02-2018 07:46 AM
boybowser
18
01-30-2018 06:21 PM
teter
10-21-2017 12:50 PM
fishfreak101
09-06-2016 10:23 AM
MarkSpillane66
1999 to 2016 Super Duty
04-28-2016 10:45 PM
Quick Reply: 1996 F250 HD: Turns over, but won't start, argh!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
