Operating Temps for Gauges
Old Feb 18, 2012 | 04:42 PM
BLADE35's Avatar
BLADE35
Does that help or Not ???????????
Old Feb 18, 2012 | 04:45 PM
Teds's Avatar
Teds
yes,i see what you are saying now, so are you saying i need to go check each one of these???
to check at the higher rpm(2500) would that be driving or just parked holding accelerator
zhilton's Avatar
zhilton
Originally Posted by Teds
oh this is just great.......ugh......so is there anything in particular to use to clean out the coolant other than water??
You can use Restore (available at most truck shops like Navistar, Mack, KW). You want to use distilled water to get it completely flushed out....usually about 5-6 drain, refills, run, drain cycles. By that point you'll in theory have only water in your cooling system. At that point, drain the water out (pull lower radiator hose) then refill with Ford Gold or Cat ELC coolant. The down side to the Ford gold is particulates...thus most guys are going back with an extended life coolant like Cat ELC-1. Make sure it isn't 50/50 premix...other wise it will be too weak; using the methoud of 5-6 good flushes with water then refilling with pure coolant will give you the exact ratio you need for -40F below protection.
replace cooler w OEM??? if so do u have part #??
But of course....
Riffraff Diesel: Ford OEM Oil Cooler
Old Feb 18, 2012 | 04:54 PM
BLADE35's Avatar
BLADE35
Not nessaserly
But if you had a drivability concern you would check said sensors for whatever operating system might be causing your drivability issues
Yes all in park holding accelerater pedal at 2500 rpm and would be Best to be at Normal Operating temp to so an ECT of 190*
Old Feb 20, 2012 | 01:14 PM
Teds's Avatar
Teds
monitoring this SGII i have noticed my water temp never goes over 190*, is that the max temp for scan gauge or is that just the highest the water gets?? EOT still running 16-17* over water, highway driving only....
Old Feb 20, 2012 | 01:33 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Are you using the stock *fWT? You can program in an x-gauge to read ECT, and if the two are reading the same then the gauge is probably working correctly. It should go over 190*, but if it's cold outside (less than 50* does this to me) my truck will run as low as 186-188* on the highway. Cracking 190* takes punching the throttle for a run up a hill or ramp, but that kills the ECT/EOT comparison of cruising at 60mph on level highway.
x-gauge coding for ECT:
TXD: 07E0221139
RXF: 046205110639
RXD: 3008
MTH: 000200010000
NAM: ECT
This is the x-gauge coding for the built-in *fWT:
TXD: 07DF0105
RXF: 044105050000
RXD: 2808
MTH: 00090005FFD8
NAM: FWT
https://www.ford-trucks.com/forums/1...l#post11432606
Old Feb 20, 2012 | 02:10 PM
Teds's Avatar
Teds
yes i am using the wt gauge ....i will go program the ECT gauge now and check it this pm.....thnx tex
Old Feb 20, 2012 | 02:43 PM
jp45601's Avatar
jp45601
blade-- i have no idea what i am suppose to do with these values??? help....
Go to the TECH FOLDER. There you can find out how to properly do a Coolant Flush & Coolant change.
Old Feb 20, 2012 | 04:59 PM
Teds's Avatar
Teds
.But of course....
Riffraff Diesel: Ford OEM Oil Cooler[/quote]
tried to contact but closed do u have any idea on shipping charge and delivery time to oklahoma??
Old Feb 20, 2012 | 08:04 PM
BLADE35's Avatar
BLADE35
There is only 1 ECT sensor on the 6.0L
So with that said you cant use fWT & ECT to check each other to confirm a bad sensor
Since they both read off the same sensor if the sensor is giving a bad reading both Gauge readings will be BAD
A Good thermostat should hold ECT at a Minimum of 190* regaurdless of ambeint temp
If you are running less than 190ECT the thermostat is hanging open alittle
But a 186-188 ECT is not tofar out of spec yet IMO so id leave it in there
Old Feb 21, 2012 | 01:20 PM
Teds's Avatar
Teds
should the ECT and the EOT always be within 6-7 * ??
it stays abt the same idle or around town, but on hwy as in today it is a little warmer outside and i was at 190ect and 209eot, question is is it suppose to be higher when hwy driving?? thats at a 20 drive down the hwy??......
will flushing and cleaning the system clean out the cooler??
Old Feb 21, 2012 | 04:12 PM
Teds's Avatar
Teds
update-- i loaded the ECT xgauge ...it showed the same temp as the WT....both did go to 192 last night.....i prefer the ECT one
where did u get the ECT info it was not on SG/support site
Old Feb 21, 2012 | 04:22 PM
  #28
texastech_diesel
Token Redneck
There's a list floating around:
Originally Posted by Internet Commandos
Here is a list of Xgauges. They have operating values listed. ICP-psi, ICP-volts and IPR% will help with HPO testing. Compare your values with those. Make sure FICM is tested when cold. Then the others are hot values. And high idle, from what I have read here is 2500 rpm. for testing purposes.
If someone has other Xgauge recommendations for testing HPO that I have missed, jump in !!!!
KO=KEY ON LI=LOW IDLE HI=HIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
?TXD: 07E02209CE
?RXF: 0462450906CE
?RXD: 3010
?MTH: 006401000000
?NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
?TXD: 07E02209CF
?RXF: 0462450906CF
?RXD: 3010
?MTH: 006401000000
?NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
?TXD: 07E02209D0
?RXF: 0462450906D0
?RXD: 3010
?MTH: 006401000000
?NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
?TXD: 07E022096D
?RXF: 04620509066D
?RXD: 3010
?MTH: 00647FFF0000
?NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
?TXD: 07E0221310
?RXF: 046245130610
?RXD: 3010
?MTH: 00090005F05F (00090005FFD8 alternate MTH found)
?NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Inj. Control Press. (ICP / HPOP)
?TXD: 07E0221446
?RXF: 046205140646
?RXD: 3010
?MTH: 003900640000
?NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
?TXD: 07E02216AD
?RXF: 0462451606AD
?RXD: 3010
?MTH: 004827100000
?NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
?TXD: 07E0221434
?RXF: 046285140634
?RXD: 3008
?MTH: 0DCA03E8000A
?NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
?TXD: 07E02209CD
?RXF: 0462050906CD
?RXD: 3000 (3001 alternate)
?MTH: 000100010000
?NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Intake Air Temperature 2 (Fahrenheit)
?TXD: 07E02216A8
?RXF: 0462051606A8
?RXD: 3010
?MTH: 000100010000
?NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Barometric Pressure
?TXD: 07E0221127
?RXF: 046285110627
?RXD: 3008
?MTH: 003100500000
?NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI) ?
Exhaust Back Pressure
?TXD: 07E0221445
?RXF: 046285140645
?RXD: 3010
?MTH: 001D00500000
?NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Manifold Absolute Pressure (PSI) (BOOST)
?TXD: 07E0221440
?RXF: 046285140640
?RXD: 3010
?MTH: 012203200000
?NAM: PSI
MAP is a standard gauge - but this XGauge is actually better than the standard one. It has a larger range which was needed because the standard gauge tops out around 37 psi absolute (about 22 lbs of boost), which diesels have no problem doing. This one should read well beyond 22lbs of boost.
?With a little tweaking you can adjust this to read boost as you said.
??To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table
12.7 FF81
12.8 FF80
12.9 FF7F
13.0 FF7E
13.1 FF7D
13.2 FF7C
13.3 FF7B
13.4 FF7A
13.5 FF79
13.6 FF78
13.7 FF77
13.8 FF76
13.9 FF75
??14.0 -- FF74
?14.1 -- FF73
?14.2 -- FF72
?14.3 -- FF71
?14.4 -- FF70
?14.5 -- FF6F
?14.6 -- FF6E
?14.7 -- FF6D
?14.8 -- FF6C
?14.9 -- FF6B
?15.0 -- FF6A
??So, for example if you got a reading of 14.5 PSI with key on engine off you'd change the MTH to 01220320FF6F and the reading should read 0.0 with key on engine off and would then show how many lbs of boost you were at when the vehicle is running.
DTC Count (Diagnostic Trouble Code Count)
?TXD: 07E0220200
?RXF: 046205020600
?RXD: 3008
?MTH: 000100010000
?NAM: DTC
Counts trouble code cycles
KO=0 LI=0 HI=0 OR=0 - 255
VREF (Calibration Voltage Input)
?TXD: 07E0221155
?RXF: 046245110655
?RXD: 3010
?MTH: 006433330000
?NAM: CVI
KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage
Old Feb 21, 2012 | 04:27 PM
  #29
Teds's Avatar
Teds
thnx tex......
Originally Posted by zhilton
You can use Restore (available at most truck shops like Navistar, Mack, KW). You want to use distilled water to get it completely flushed out....usually about 5-6 drain, refills, run, drain cycles. By that point you'll in theory have only water in your cooling system. At that point, drain the water out (pull lower radiator hose) then refill with Ford Gold or Cat ELC coolant. The down side to the Ford gold is particulates...thus most guys are going back with an extended life coolant like Cat ELC-1. Make sure it isn't 50/50 premix...other wise it will be too weak; using the methoud of 5-6 good flushes with water then refilling with pure coolant will give you the exact ratio you need for -40F below protection.But of course....
Z--you say restore but as i have been reading there is restore, restore +, and vc-9, which one do i need to use??
Old Feb 21, 2012 | 04:31 PM
  #30
texastech_diesel
Token Redneck
Restore+/VC9 are iron scrubbers. Restore removes silicates. Use Restore, than either of the others.
olfordsnstone
Dec 31, 2017 08:46 PM
tunaguy
Jan 28, 2016 11:01 PM
rtwilliams
Jan 12, 2014 03:32 PM
rthacker
Jul 1, 2010 07:00 PM
hndacr
May 31, 2010 09:12 PM
