The Adventure Begins: My '81 F100 Project
#707
A few steps closer to completion. To keep an eye on those gasket tabs, I started at a rear corner and worked my way around, inserting each bolt just a couple of turns. Then I went back around and hand-tightened them with a 1/2" socket on an extension. If you undertake this, do yourself a favor and scrounge up every 1/2" socket you have, and attach to them to a variety of extensions; it will save you from having to switch the socket in a fairly tight spot.
I should have painted the bolts, but they'd just get all buggered up by the sockets.
Another note: To remove the oil pan, I had to bend that brace on the dipstick tube, the one that attaches to the fifth push rod cover bolt.
Heading back out to torque them all to 15 lbs., and remount the starter.
#709
#710
It's been said before and I'll say it again, this thread is downright inspirational. Anytime I read it I just wanna drop what I'm doing and go to work on the ole' girl. And also it seems like such a simple problem but I have been confounded for the longest on how to paint my rims without getting it all over my tires, so thank you for all the awesome advice and ideas!
#711
Makes 'em shiny looking!
#712
#713
I 'preciate that, brother. I've tried to show not just the work being done, but a lot of tasks for which I couldn't find photos online or anywhere else. And practically everything I've done to Festus has been with the aid of FTE members and a good set of manuals. Sometimes it takes a while to find it, but if you're doing it to your truck, there's a good chance it's been discussed somewhere on this forum. If it hasn't, just ask, and the good folks here will jump to your aid.
#714
#715
Received my new vinyl flooring today from Stock Interiors, only four days after I ordered it. It's heavier (almost 30 pounds) and thicker than the original, and looks like it will extend all the way under the seat. I'll have to leave it laid out for a few days for the wrinkles to soften, before I can install it. Really looking forward to this, as the old vinyl piece is a goner, lots of rips and holes.
1980-1986 Ford Full Size Truck, Standard Cab Molded Vinyl Flooring - 2 WD Floor Shift or 4 WD (High Tunnel)
#718
It'll be mighty fine, alright. The texture's the same, but it doesn't have the ribbed area on the driver's side. No problem, I'll be putting mats in anyway. My understanding is, they use actual floorpans and cast the vinyl on them. It's also available in dark gray, beige, and medium blue. The padding in the photo is included, so I can finally get rid of the original jute padding, which is like handling a porcupine.
When I pull the original, I'll get the cab mounts done so I don't have to remove the new vinyl. I'll also insulate the firewall.
This is the best photo I could find of the stock flooring, when I was cleaning it a year ago.
#719
I seem to remember a trick for getting the vinyl to smooth out, something like using a hairdryer to warm up the vinyl. I think I read it somewhere.
Yours was in alot better shape than mine, it was coming apart everywhere and got bunched up in places. Now that I think about it, I think my truck had bare floor when I got it, and the rubber mat I had in it before I put in carpet came from a parts truck.
I wouldn't trade my carpet for anything now but then again, vinyl is alot easier to get stuff out of than carpet. lol
#720
I went back and forth for a long while trying to decide if I'd install carpet; but given where we now live, with directions including "turn off the paved road", I opted to stay with the vinyl.
If I had ordered this in the summer, it would probably be ready to go now. But, it is noticeably softer this morning and starting to take shape. Also a closeup of the texture.
The original has gotten thin and brittle over the years. Through various projects in the cab, it has torn every time I've moved it.
