Cold Start Problems...
Old 01-18-2012, 06:59 AM
kjf-250's Avatar
kjf-250
kjf-250 is offline
Okay so I'm trying to troubleshoot a cold start problem on my dads 07 F-250 6.0 which has 180,000 miles on it. It is taking a good 8 or 9 seconds to crank, then running rough and smoking a lot! I'm afraid when it gets cold enough it's not going to crank at all. It had a few glow plugs out, as well as the GPCM, so I replaced all of those thinking that was the problem...but I was wrong. All the glow plugs are working, but the symptoms are still the same. With no CEL, I think it almost has to be the injectors sticking. I have switched it to 5W40 T6 synthetic and ran additives through it to no avail. My question is is there a way to test the injector to see which ones are bad/faulty without having to replace them all? Any advice would be appreciated!
~Kevin
Old 01-18-2012, 07:19 AM
bismic's Avatar
bismic
bismic is online now
Received 2,490 Likes on 1,727 Posts
Check FICM voltage (cold engine):
KOEO
cranking
at 2000 rpm
Use an OBDII scanner that reads the voltage or CAREFULLY check the voltage at the proper terminals under the FICM cover plate (instructions in the Tech Folder).
Make sure batteries are charged and individually load tested.
Old 01-18-2012, 07:45 AM
kjf-250's Avatar
kjf-250
kjf-250 is offline
Thanks for the info! Batteries are charged and fairly new, shouldnt be a problem there. Can the FICM cause cold start problems? I guess that makes sense though, just hadn't thought of that since it only does it when cold...
Old 01-18-2012, 08:43 AM
sarnott140's Avatar
sarnott140
sarnott140 is offline
Like Bismic said, check FICM voltage, I had the exact same symptoms when mine went bad. Send it to FICM Repair.com - Your Source for FICM Repair if bad. WAY cheaper than buying a new one and they replace failed components with upgraded one's so its better than new.
Old 01-18-2012, 09:16 AM
kjf-250's Avatar
kjf-250
kjf-250 is offline
I'll be sure and check it! I thought that the white smoke would point towards injectors as opposed to the FICM. Guess you learn something new every day. Could it still be the FICM even if the truck runs perfect when its warm?
Old 01-18-2012, 05:14 PM
bismic's Avatar
bismic
Highly likely - that is why we recommended it.
Old 01-18-2012, 06:24 PM
kjf-250's Avatar
kjf-250
kjf-250 is offline
Okay thanks! I'll check it as soon as I get a chance.
Old 01-18-2012, 10:54 PM
windoman's Avatar
windoman
windoman is offline
Just had that problem with my 04 f250 sd 6.0 turbo diesel it was the ficm.
Just found out there was a recall in 2005 on this part.
Old 01-19-2012, 05:27 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Do NOT take your batteries for granted. From experience, I've found that battery age has nothing to do with battery life. New batteries can go bad too.
Old 01-19-2012, 05:28 AM
bismic's Avatar
bismic
I have not ever heard of a FICM recall. Please post more info - source, details, etc.!
npccpartsman
I've never seen or heard of a recall on FICM's. Can you provide some documentation? I'd like to get a few $$$$$ back if that's the case.
Old 01-19-2012, 07:56 AM
Dawgman's Avatar
Dawgman
Dawgman is offline
I wonder if this is the recall???
2005 FORD F-250 SD Recalls
Old 01-19-2012, 02:07 PM
npccpartsman
That's a recall for the FICM harness and EBP connector, not the FICM itself.
Old 01-19-2012, 07:32 PM
Dawgman's Avatar
Dawgman
Dawgman is offline
Yep, that's what I thought....My truck is going in the shop soon before the extended Ford diesel motor warranty expires. It doesn't get crazy cold here, but when it gets below freezing, my motor sounds like it's going to explode when I first start it up. Got 160,000 miles on it so far, and the warranty expires at 200,000. Hoping it's a fuel injection problem and not the FICM.
Old 01-20-2012, 08:04 PM
FICMrepair.com's Avatar
FICMrepair.com
FICMrepair.com is offline
Former Vendor
You might want to check the FICM voltages yourself before taking it in. If you see the voltages low in that case, you are in a way better position to have them give you a replacement *under warranty*.
Ed
Ed@ficmrepair.com
Quick Reply: Cold Start Problems...
