55 239 Y-Block Restoration Thread
#331
Well, I got the other half of the u-joint out just fine.
I've tried pressing it back through but it is just not fitting in there. It is starting to damage the yoke a little trying to press it back through. I think I'm going to have to take it to someone that has a good press and knows what they are doing. Wish I would have started on the other end. I would never had to mess with this end that is causing me issues.....
#332
#333
Propane torch....another reason to visit my dad...I really should go buy one they can come in handy. Getting tools is a slow process for me just like the progress on my truck.
Well I guess I will come out of the closet and show my redneck press.
My vice is too small so I got to thinking what I could use. Well, my truck came to mind. It's not quite heavy enough, so I would jack it up about 1/4 of an inch and let it settle. It worked slick although it took extra long. Getting everything lined up was a challenge.
#337
#338
#339
Jeremy, it sounds like you launched that Nova a lot.
Did that fall under the lifetime warranty of u-joints?
Well I went out at lunch and got a torch. Now if I could only get out of tonight's plans....oh well, my wife isn't excited about tonight and told her family that she has to come home tonight, so I will get some time in the garage tomorrow.
I appreciate all your suggestions and encouragement.
#340
Gotta vent for a minute.
I've torn this truck apart, started putting everything back together without ever doing anything like this before, got the engine cleaned up and running after 40 years of sitting. And now simple U-joints are causing me all sorts of frustration.
I got the piece that connects to the transmission out just fine. I tried heating the yoke and the cup still won't budge. It's possible I got my heat too close to the cup as well. Then I go and drop one of the other cups and needle bearing flew. Joe, how did you cut your u-joint? It looks like a slick cut. I probably don't have those tools though.
Well, then I figure I will just put one of the other u-joints on. I get one side in just fine. The other side is in, but it still needs to go down about a millimeter to fully expose the groove for the clip. I can't get that to budge any further. Time to find someone with a press.
Well, I can look on the bright side. By the time I'm done, I will be very good at dealing with U-joints. Shoot, this sounds very similar to my brakes.
Well off to work while the kids sleep in because school was cancelled because of a dusting of snow. (maybe an inch)
#341
#342
#343
Yeah, I'm sure it wouldn't cost too much. I was just hoping to be able to do this myself and learn some more. Not having the proper tools puts me at a disadvantage though. I will probably run them out to a shop when I get a chance. I think I will remove the one and see if a needle bearing did in fact slip.
#344
Well, I had to come home to take my oldest to a Doctor appointment and there was a nice package that had been delivered.
I got my drag link repair kit and my crankcase breather screen.
Funny thing about the breather screen, I looked at all the local stores online and couldn't find it, so I bought it online. When it arrived it turns out to be a WIX 42841. O'Reilly's has those, they just say they don't fit my truck. And it was even cheaper at O'Reilly's. I can't verify that they can get it in the store but it is available online.
So, for future searchers. Here is the cross reference for the Crankcase Breather Screen.
Ford Part Number: B2TZ-6A631-A
This includes the gasket B7A-6870-A
Replacement part is: WIX 42841
WIX says this filter is for Ford Cars and Trucks 1952-1963
Being curious I tried to find cross references the NAPA filter is: FIL 2841
That was the only other one I could find in my short search.
#345
Well progress. I don't know if it is a privilege or curse for you guys to have to watch me learn.
I pulled the U-joint back out and there was a needle bearing in the bottom. I got that back in place and tried to put the ujoint back on. Well I did it again this time I actually broke a needle bearing. I just took a cap from the other u-joint that is still stuck. Third times a charm, I now have one U-joint in and working slick.
For the broken needle bearing, I thought I would try one of the bearings from my old u-joints. Well they are actually thicker and shorter.... I look at it this way. It cost me one u-joint to get a lot more knowledge on how to remove and install them. That's pretty cheap I would say.
Now on to getting the other one out. I have an idea on heating it so it will move. The first time I think I heated the cap to much as well. Hopefully I will have a chance this weekend to try again. Hopefully that will go smoother as well.
Anyone reading this thread looking for answers. An old dog can learn new tricks. Patience and persistence. Until the next simple thing trips me up.
