55 239 Y-Block Restoration Thread
#1546
Or if you want to let Abe save the NOS striker for a restoration, scuff the chrome and spray a dust coat of argent paint...........The paint will mask that darkside look...........A slight covering with oil on the striker plate to collect some dust and dirt, you'll never notice. Of course, you may have to replace the new striker plate in a few years as it wears out from interacting with good American steel.
#1547
Joe, there is a NOS striker plate on ebay now for $7.50 right now, passenger side. and if you don't buy it I will! https://www.ebay.com/itm/Striker-Pla...~fpv:rk:2:pf:0
Even if you need a drivers side you should have the right side for backup.
There are driver side listed but they are more expensive as they wear out faster and are scarcer. I have drivers sides and can part with cheaper than what they are asking for on ebay. CArpenter sells the shiny ones for $19.95 plus his $9.99 shipping. Mid West might have lower shipping for you to MO.
#1548
I've got Abe shipping me an NOS striker plate. I did buy the passenger side one on ebay as well. It never hurts to have extra.
I've been talking on the thread Question about wheel bearings about my shimmy.
My wheel bearings were a little loose so I repacked the outers and tightened them back up.
Here is a video of my passenger tie rod end. How do I best fix that? Can I tighten it? I'm afraid the axle piece (whatever it's called) is too big and I need to do something special.
#1550
https://www.youtube.com/watch?v=HZf_UiuPUMM
#1552
I need to get my daily driver inspected. I think I will show the guy there the video and get his thoughts.
New tie rod...one more thing to add to my Christmas list...nah...time to head to the store.
#1553
Joe, I think a Gatorade bottle is perfect for a cross country runner like yourself! Better yet it should be a vintage glass Gatorade bottle from back in your hey day!
#1554
Joe, is there any chance that tie rod end did not get pulled into the steering arm good and tight when it was installed? The movement appears to be between the tie rod end and the arm, not in the tie rod itself. Or it could be the case of the tie rod end was made out of recycled beer cans and is soft. Or, maybe the tie rod end is too small for the arm.
#1555
Glass Gatorade bottle wouldn't be bad. I will have to ponder some ideas around that. If I have a better mounting system than my string, that would make a big difference.
Ray, I will check and see if the end is in the steering arm properly. Maybe that's it...that would trouble me more on my alignment guy though....
If I tighten it up, that will answer many of your questions. The movement is between the tie rod end and the arm. It is in the tie rod solid.
We have a guy coming to look at our house for new carpet tomorrow and we are showing our other house Saturday. So, not much shop time this week.
Oh, you might enjoy this story. We go to the carpet place in town (our town is about 4000 residents) Gwen and the store owner were pondering how old the carpet is. Well, the guy that installed it committed murder at the age of 21 and has been in prison for a bit over 20 years. So, they figured the carpet is about 25 years old. Another customer and I were cracking up. How often do you hear people discussing carpet age based on a murder. It seems this guys girlfriend told him that her step father had molested her. So, he promptly went out and hung the step father. Dang, this was around the time of the Jim Johnson murders here in town. (He killed the sheriff's wife and several deputies) The early 90s were rough around here.
#1556
Joe, is there any chance that tie rod did not get pulled into the steering arm good and tight when it was installed? The movement appears to be between the tie rod end and the arm, not in the tie rod itself. Or it could be the case of the tie rod end was made out of recycled beer cans and is soft. Or, maybe the tie rod end is too small for the arm.
Good catch .
#1557
Inspect the steering arm carefully. If the tie rod end has been loose for some time it could have worn the hole in the steering arm bigger, or changed the taper. If this is the case, the tie rod end won't stay tight.
One of my originals was so worn it was egg-shaped and the taper was almost worn away.
#1558
My book says TAAA 3130-A
Hopefully not necessary, but good to have the info handy.
It looks like they may be hard to find. Here is a thread form 2014 https://www.ford-trucks.com/forums/1...d-tie-rod.html
#1559
That is one of my fears. I had better start searching for a replacement just in case.
