55 239 Y-Block Restoration Thread
#1520
I'm headed to Rosebud tomorrow.(A little spot in the road between me and St. Louis) I sold a 54 grill and radiator bracket and we are meeting there to transfer. The guy says he has a 55 with a 53 grill and likes the 54 grill better. More power to him.
I've been working a little bit on my Dana 60. Getting the shoes on is driving me nuts. That stupid spring just won't hook up to the holder for me on the fourth shoe.(The red one) I know I'm a scrawny guy, but dang!
Also, did I miss anything? I didn't add the emergency brake lever since I won't be using it. I'm such a novice at this stuff, I guess that's why it takes me forever to get anything done.
The springs on the ground are extras from the kit I bought. I got a bit worried until I went to my box of old stuff and counted springs.
#1523
Yep, sure do.
Also, I think I have it all on backwards. I've read where the big shoe goes on the back, but all the hardware indicates the self adjuster should be on the front.
I wonder how much it matters. I guess I need the practice and can pull all of this off and put it back on the other way.
#1524
Couldn’t tell by the picture what side it was but the bigger shoe (more brake lining) goes to the back. Reverse them and your braking gets a little squirrelly. In your case the self adjuster won’t matter as much because you’re not using the backing plate mounted parking brake. If you were the application of the parking brake helps to adjust the shoes.
#1525
#1526
I did the e-brake quite a while ago.
Here is a bit of it from this thread: https://www.ford-trucks.com/forums/s...&postcount=362
Here is another good thread on lining material: https://www.ford-trucks.com/forums/1...t-e-brake.html
let me know what questions you have and I will try to dig up some answers and pictures.
Good point on the adjusters, I will double check those.
I was wondering about the self adjusters if I don't have the ebrake. Are they worth having in there or should I just get them out of the way. If I want to adjust by hand, they make it more difficult.
#1528
Joe, I'm sorry to hear of your loss. You have my sympathy at this difficult time of parting. As you well know, your sister has gone to a far better place to be with her Lord. We have God's promise that her absence will only be for a short time, and we believe that you can confidently look forward to a reunion with her in heaven.
Jim
Jim
#1529
