Low oil shut down
Old 01-20-2012, 09:58 PM
dwigmore's Avatar
dwigmore
dwigmore is offline
Low oil shut down
It's happened a couple of times now. On the way home. The oil pressure light came on and the engine quit. Put it in park, waited a minute, then started it up and everything is ok. Oil was just changed a few days ago, oil level is still good. It's cold out, but I don't think that should matter. Ideas?
Old 01-20-2012, 10:51 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
What weight oil was put in? Could be a pump failing, clogged pick up or a bad sensor Or if some really crazy thick oil was put in it who knows what could happen. i.e. 20w50 and it is -10F outside.
Old 01-21-2012, 12:53 AM
dwigmore's Avatar
dwigmore
dwigmore is offline
5-20 oil (or so they said). It was Ford that did the oil change, but you never know I guess! Are there any known issues with this engine (supercharged)?
Old 01-21-2012, 05:10 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
These trucks don't have a low oil pressure shutdown. Any pending codes? My guess is the engine is being shut off either by the PCM or by a faulty ignition switch then the low oil pressure light will come on.
Old 01-21-2012, 08:41 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
I'm with 'gashog. The oil light is a result of the stall as the engine oil pressure falls off.
Might be either an ignition system or a fuel delivery problem, but it's likely going to take some patience and persistence (or just plain luck) to accurately diagnose so it can be repaired.
If you want to take a wild stab at it, replace the PCM Power relay and see if you get lucky.
Old 01-21-2012, 08:47 PM
jayton4's Avatar
jayton4
jayton4 is offline
what's the mileage? Any noises or loss of power when driving?
Old 01-21-2012, 11:07 PM
dwigmore's Avatar
dwigmore
dwigmore is offline
Thanks all - the truck has around 70k miles, doesn't make any weird sounds or anything. I'll try to pay more attention to it next time it quits. Electrical issues can be a pain to find - especially when it seldom acts up! I do feel better knowing that it's not shutting off due to no pressure though - Thanks!
Old 01-21-2012, 11:12 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
You might try getting rid of the edge programmer and see if that changes anything , Those things can do some pretty weird stuff..
Old 02-14-2012, 03:48 PM
dwigmore's Avatar
dwigmore
dwigmore is offline
Update
So after having the O2 sensors replaced (no help there), I had the main computer replaced. I don't really understand why it was acting up, but for the first couple of weeks I need to depress the accelerator pedal slowly so the new computer can learn the range of motion. Sounds weird to me too, but didn't do it once, and the truck stalled out.
Old 02-15-2012, 01:24 AM
RocketmAAn's Avatar
RocketmAAn
RocketmAAn is offline
I assumed you aren't low on oil? When I got a hole in the front engine cover recently I had 0 pressure suddenly going around a corner. Turns out the "guage" is an idiot light in guage form and I was off the dipstick low. Above a certain pressure guage is up there around the 3/4 mark. Below an it "plummets" to zero. When I added oil, started getting a ticking noise (which I've preliminarily concluded is from something like busted plastic/nylon timing tensioner or guide inside the front cover (near the hole)
nwgal65
Oil & Lubrication
11-22-2012 11:08 AM
rick-73
49
04-15-2010 04:42 AM
rmalottwtes30
03-06-2008 06:33 PM
amw_drizz
1978 - 1996 Big Bronco
22
03-14-2005 05:16 PM
RangerDJB
Oil & Lubrication
01-19-2002 02:30 PM
Quick Reply: Low oil shut down
