New Truck! UPDATES!
New Truck! UPDATES!
I recently had a deal fall through on an F450 that leads me to this, I bought a 2000 F350 Crew Cab V10 2wd today with 160,000 on it formerly used as a rail-road truck and VERY well maintained. The interior is not too bad for being a work truck and the ac works! I plan on removing the PTO, Track wheels, the large heavy brand new 19.5 inch wheels and doing an 05 front end conversion once spring hits. I will add more pics later but here it is!
They removed one wheel at each corner so you cant do that But It would be cool! They guy I bought it off of had 17 of them this was the last of them! He had a few with the service boxes on them that were diesel 4x4 but those went for 5,000 each I paid 3500. One owner fleet maintained
Well today was the first not rainy cold day out so I was able to do a little removal. I removed all the junk from the bed. Tool box, (cracked and leaks) , headache rack and about 5 miles of old wiring used for the PTO and pumps. I changed the trans fluid and filter and found out I have a newer transmission hence the no TQ drain plug. I have also removed the running boards and got some aftermarket OE looking wheels! I will post more pics tomorrow! Now I can remove all the PTO lines and cooler from the truck and deal with the coolant lines that ran to the Hydraulic oil tank. I will add new pics as things get taken off and added!
uc4me
18
05-08-2008 07:59 AM
