Why Tap Splices Should be Illegal
I totally agree with Ed about soldering, if you dont know how to do it you sure can screw it up. Cold solder happens all the time. I see it at least once a week on F16's where they find a cold solder that will cause hours of of troubleshooting to find the soldering job botched up. There are diff kinds of solder to use that can be the wrong one also.
"Experimental Missile Electrician", which meant I worked on a lot of one-off
military, commercial aviation, and space projects. I went to a two-day school just
on soldering alone and I learned how soldering is not just "heat and apply" to get a
durable connection. I've repaired thousands of cold solders in my various careers,
including the overhead readout in my Superduty. Cold solders are a real bear to
troubleshoot and while many people know how to prevent this - many more don't.
Another side-note:
What would also apply is to appropriately re-size photos, but it seems most people haven't any idea how to do that.
A good rule of thumb is to not have the photo any wider than about 600 pixels. That's enough for good definition, and will not likely
be wider than anyone's screen.
But it's not my place to be the Posting Police, so it's just a suggestion....
Pop
Pop
I apologize if it is too big - but I wanted to display the full use of the filled
Scotchlok and how tidy the installation looks. You can also look at the connector
in use with detail. I will bring this up in another thread, for the sake of getting more
input from other readers and I respect your opinion on this. I have been working
with digital imaging professionally and/or as a hobby since 1985 and that's about
the same time I started working with computers. While I have advanced
hardware/software, I understand many people have 4:3 displays with resolution no
greater than 1024 X 768 and I keep my images down to that size or smaller. The
old glass monitors can be as small as 640 X 480, but the whole internet would be
difficult to view with a screen that size, not just FTE.
By the way, formatting the text to fit on the left is a PITA... this is the first time I
was aware of the issue and tried to do something about it. I'll try to figure out
another solution and share any discoveries.
There it is - even soldering is no guarantee. I used to work for Boeing as an
I use Butt Splices for all my connections. However each one of them runs about a buck and they are both heat shrink/seal, crimp and sodered connections.
They are in FACT stronger then a sodered connection with shrink wrap.
Check out your local fastenal for the connectors, but be prepared to pay.
I bet the first 'project' for every vehicle I've ever owned was to fix the PO's wiring. Whether it was stereo's, trailer lights or 'repair' jobs - I am pretty sure everything I have ever owned had something I was inclined to fix.
Besides RV's, the WORST offenders anywhere have to be the up-fitters and other hacks who install flatbeds, utility boxes, etc... Maybe not as bad as the 'truck stop chrome shop' guys though!
Here's one from not too long ago on another forum:
http://i1091.photobucket.com/albums/...8/IMG_7112.jpg
click edit and press enter after every XXX number of characters. (For me it is about 100 characters.)
I think this is the only forum i must scroll on.
Funny that were talking about splices and soldering because today we had a jet abort his take off due to a flight control problem. After 5 hours of troubleshooting they found the flight control wing root waffer stack (wiring stack) had 11 cold solders on it. By looking at it, it looked fine but really it was cold soldered.
I bought my enclosed trailer for $400 it's only 5 years old not in too bad of shape.
When I got it the brakes were not in working order on all but 1 wheel.
I jacked up each side and found the manufacturer had used splice connectors to connect the brake wires.
About an hour and some solder later all wheels came to stop with a nice "Thud" when spun in the air and the trailer brakes applied. I'm sure it's only a matter of time before I have to go back and redo that last wheel but it was cold the day I did the others so I wasn't looking for extra work.
Now when you are trying to fix a problem like that on a F16 are you allowed to probe wires or are you only allowed to go from connection to connection. I would think they don't want you poking holes in wires.???
Rob I would think on a F16 they could come up with a more techie name that "wing root waffer stack" It sounds like something you would get at the WaffleHouse for breakfast. LOL
No probing wires, only connector to connector.
Of my three screens, my laptop is my smallest one (1440 X 900) and it displays FTE full-width without scrolling. I don't see the issue at home, but I remember using a 1024 X 768 screen on another computer once and I did have to scroll. I've contacted FTE on this and I'll be coming up with suggestions on screen display soon.
#28
#29
The "cold solder" problem has only gotten worse, with the EU implementing its "Removal of Hazardous Substances" act, and most companies following suit. Of course, lead is considered a hazardous substance, and is thus prohibited.
Lead-free solder is less pliable than lead/tin solder, and with repeated temperature cycling, will result in more fractured solder connections. This is mostly a problem in consumer goods. Pretty much any electronic products that you buy now will be RoHS compliant, and thus have lead-free solder.
LARIAT 85
29
03-11-2016 03:35 PM
bigredtruck
18
04-24-2006 02:05 AM
stepside64
09-14-2003 12:19 AM
