I think so too. I have a gravel driveway and drive through the fields all the time (unless it's wet, but who wants to rut up the pastures anyway?). Since I leave the paved road every day, I don't want to use it, even though I would probably be fine to do so. It doesn't hang down that much further than the pan.
Just pound the bottom of the filter in a bit with a hammer for clearance.
I added a home made bypass filter so I already use 4 gals, but when I change the bypass filter every 5, I still gotta add a quart.... So every 15k I only use 18 qts.
With the Donaldson Filter and Rotella Synthetic, would that extend your oil change intervals?
It has that potential. the only way to know for sure would be to have an oil analysis done. I usually run mine 5-6K. I can usually tell by the way it sounds that is due for an oil change. Of course mine works pretty hard. Other truck owners may, and often do go many miles farther.
I figure a $125 oil change is cheap compared to 10K-15K for an engine.
