Did the USB2 "mod" today
#46
Why would you store your music by playlist instead of artist? That's like storing your socks, underwear, shirts, pants, etc. by day of the week instead of by function.
Simply create a folder for each artist on the root directory of the flash drive. Use MP3TAG to create playlists. I have a little over 2700 MP3s and M4As on my flash drive and it took me about 30 minutes to create 50 different playlists. The playlists are also very easy to edit using notepad (or simply creating a new one).
#47
I guess it just depends on how you listen to music. I do have two playlists that are just one artist, but the rest of my playlists are just a collection of various artists and I simply have my music set on shuffle and it just plays random songs in that playlist. If I ever want to listen to one artists, I'll just create another playlist for them.
#48
How you listen to the music has nothing to do with how it's stored (just like how you store your clothes has nothing to do with when you where them). That's why we create playlists.
Playlists can be any combination of artists, albums, genre, etc. All they are is simple ANSI text files.
It's about being able to easily keep you current and new music organized. Storing by artist (and even by artist AND album) makes this process a lot easier.
#49
#51
I see. Yea, if my Pioneer HU did a better job organizing files I would have done the whole artist thing, but the HU is bad at that. It is basically like plugging the sd card into a computer and looking at it that way; displaying raw files and folders. If his head unit does a good job organizing files then by all means do it that way, I just recommenced it my way because that is what worked for me.
#54
#55
Do you have a girlfriend or wife?
Wait until she puts her purse on top of your iPod and breaks the in-dash USB connector.
My 32GB flash drive (no batteries so it is not affected by heat and/or cold and it's dirt cheap compared to an iPod) is in my glove compartment and has over 2600 MP3s and M4As.
#56
My $10 USB stick is in the glove box 24/7, invisible from the outside.
#57
I do leave it in there and now I see where a $10 stick in place of the I-pod would make good sense... Are there other things people use it for?
#58
Use what for? The second USB port?
I suppose if you had a lot of music (or used high bitrates - 320kbps) you could have two USB flash drives in the glove compartment and then switch between them.
Only one can be an active audio source and trying to use the second as a charging port (for your phone or iPod) might overload the USB controller (each port is current limited).
#59
Yeah. The issue with it sitting there (ipod or USB stick) is if somebody wants to get it, he'll smash the window most likely. And that will be more expensive than the ipod or USB stick. Hidden in the glove box is a good place for it!
#60
Flixden - I too have a new '12 model F-150. Can you please provide some more detail in your experience with removing the rubber piece on top of the dash to get to the usb ports? For example: is it glued down, how much force are did it take to "pry" it up, did you glue the rubber panel down after the mod, and do you have any rattles after putting everything back together?
I read 90% of the posts on this mod, but it seems they are mainly for 2010's. I'm just looking for your insight to 2012 specifics with this mod. Thanks for the help!
One more thing: A Ford SYNC rep in Ford's chat room told me that the largest USB storage that SYNC will support is 16GB. For you dudes that run large external hard drives and 32 and 64GB thumb drives....any problems accessing all your music from the storage?
