2001 F150 service engine light flashing
Old 02-14-2012, 07:41 PM
articmaverick12's Avatar
articmaverick12
articmaverick12 is offline
One minute truck is running fine, next the service engine light starts flashing, no exceleration and popping noises and can't get above 1200 rpms. Pull over let sit for a bit then only light is on and no symptoms for awhile then it starts all over. Weather is damp.
Old 02-14-2012, 07:54 PM
Archion's Avatar
Archion
Archion is offline
Flashing MIL usually indicates a misfire code. Pull the codes and see which is the offending cylinder(s)
Old 02-14-2012, 08:08 PM
articmaverick12
Thanks, will check codes. The SEL has been on for years, the flashing just started today. It is a wet snow outside. Last week it seemed to run rough and again it was wet out.
Old 02-14-2012, 09:00 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
dampness can effect the spark plugs / wires.. but normally after it warms up a few minutes that will go away in humid/ wet weather.
Old 02-14-2012, 11:23 PM
la90043's Avatar
la90043
la90043 is offline
The engine is probably is in fail safe mode at 1200 rpm's. the engine will limit its rpm to protect it self if the computer recognizes a potential engine malfunction. Yellow light is caution, red light is severe damage. All modern vehicle have a rev limiter when its an a critical stage. by your description the motor is going rev limitations to protect itself. lack of oil? lack of coolant?
Old 02-15-2012, 06:12 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Nah, just a severe misfire.
Old 02-15-2012, 10:13 AM
dennis350's Avatar
dennis350
dennis350 is offline
My 03 did the same thing, was cylinder 7 misfire, replaced plug and coil pack and now runs ok, I do need to change the rest of those plugs soon.
Dan Robertson
1983 - 2012 Ranger & B-Series
03-21-2019 08:31 AM
wrdabney
24
08-26-2012 04:03 PM
rustee90-150
11-11-2007 05:03 PM
dfishrmn88
Texas Chapter
02-13-2005 10:27 PM
cheg
01-27-2003 07:41 AM
Quick Reply: 2001 F150 service engine light flashing
