they dont have any in stock. at least last week they didnt according to an oilburner member.
there are some at mylex on ebay but they are way overpriced for just injectors, but supply and demand.
wondering if you could rebuild a set if the old one were sent to you ?
The other day I found a local supplier that had BB Code Delphi injectors, part #6760301, made in Mexico, new, price seemed reasonable. Parts man said he could not be sure they were compatible with my 1983 6.9L OEM diesel engine because his catalog didn't go back that far.
Will these work for me?
The 83 and early 84 'A' code injectors are slightly different, but pretty much all the others are the same. Later injectors should work fine in the 83 engine.
Turbo injectors are basically the same as well. These aren't like the powerstrokes where changing the injectors gets you more power, on these engines the injectors are basically just a nozzle. Fuel is controlled by the injection pump.
I checked my truck, I have 7 A injectors made by Bosch in Italy in early 1983 and just one AA injector made by someone whose logo starts with "C" - it has a 1985 data stamp, so is not an OEM part. They still seem to be working, but must be getting 'tired' after all this time.
Why are 7.3 IDI turbo objectors so hard to find? Are they about to quit making them or what? Kinda scary thinking in a year or two I may some and won't be able to get them
