Door Jamb Wire Connectors - Ford Truck Enthusiasts Forums
Old 02-09-2012, 11:37 PM
Ole Green 1978
Ole Green 1978 is offline
Ole Green 1978 is starting off with a positive reputation.
What kind of clips or connectors do you put on the end of the door jamb switches? It's got to have the wire clipped up in there some how?
Old 02-10-2012, 01:00 AM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
It's a special Ford 3-connector pigtail. LMC truck sells them; I'm sure other places have them too. It's item 10 on the following LMC catalog page:
LMC Truck Parts - Page 140
These are replacement connectors. You only need them if your original wiring harness is hacked up. If you simply need to replace the switch, the old switch disconnects from the existing connector, and the new switch goes in its place.
Amphihauler
07-08-2016 02:24 PM
jprix
1997-2006 Expedition & Navigator
01-08-2014 12:20 PM
Paul49
05-29-2011 11:45 AM
biggut
08-02-2009 12:22 AM
idealtrucks
04-18-2004 01:05 AM
Quick Reply: Door Jamb Wire Connectors
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
