How many qts. of oil does the 6.7 hold ?? - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 02-10-2012, 07:29 PM
suprdtydvr
suprdtydvr is offline
suprdtydvr is starting off with a positive reputation.
I have performed two oil changes so far. I have added exactly 13 quarts each time and the level ended up at the top of the range on the dipstick.
Old 02-10-2012, 07:59 PM
wtrlogd's Avatar
wtrlogd
wtrlogd is offline
wtrlogd is gaining momentum as a positive member of FTE.wtrlogd is gaining momentum as a positive member of FTE.
My dealer's mechanic said they use 14 quarts, or close to it, because 13 doesn't bring it high enough on the dip stick.
I can't really argue with him, as I can't really read the dip stick. I get a different result with every dip.
edit,
Actually, I did check it after both dealer oil changes, and a few time between changes, it's always been on the very high end of the range
Old 02-10-2012, 09:03 PM
cford716
cford716 is offline
cford716 is gaining momentum as a positive member of FTE.
Originally Posted by Ezcmpny View Post
I'll 2nd the notion that the dipstick is hard to read. I pour in 13 quarts and close the hood.
I thought I was the only one that did this. I gave up after checking it about 5 times. Good to go!
Old 02-10-2012, 09:51 PM
CascadeF250's Avatar
CascadeF250
CascadeF250 is online now
CascadeF250 is gaining momentum as a positive member of FTE.
edit,
You will find that if you let your truck sit overnight you can read the dipstick the first time you check. Keep in mind you only get one chance (you cannot double dip). I realize you are supposed to check it warm so if I check my oil during the day I let it sit for a while before trying. Another suggestion by someone else on the forum was to pull it up slightly, wait for a short time and pull it all the way out to check the dipstick. If I have any complaints about this truck it is the ----DIPSTICK----. I guess if that is my only problem-- I have no problems.
Old 02-11-2012, 01:49 AM
kper05's Avatar
kper05
kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
You only get one or two decent checks.
After that, wait until morning.
Old 02-11-2012, 12:02 PM
Baja16's Avatar
Baja16
Baja16 is offline
Baja16 is starting off with a positive reputation.
Yes i've notice the dipsticks are hard to read, not to high jack the thread but how many miles did you guys go before your first oil change?
Old 02-11-2012, 12:16 PM
CascadeF250
I changed at 6,000 miles but the dealer wanted me to wait for the information center to tell me to. The old mentality was to change on a new motor at 500 -1,000 miles but they said that is no longer the case. I still change my oil at around 5,000 miles. I usually am getting ready to take a long trip and don't want to leave with 5,000-6,000 miles on the oil. Most a majority of people with these new trucks wait until the information center tells them its time to service oil.
Old 02-11-2012, 01:10 PM
kper05's Avatar
kper05
kper05 is offline
I had the dealer change it at 4700 and then I've changed it at higher amounts each time.
This last change was close to 6,000 and had less oil growth than the previous changes.
(Too bad I forgot to take the sample but I think the fuel percentage would have been low.)
Old 08-26-2016, 01:14 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM
BROWN DOG KTM is online now
BROWN DOG KTM is gaining momentum as a positive member of FTE.BROWN DOG KTM is gaining momentum as a positive member of FTE.
Old Thread Revived
I drained oil & removed filter on my 2016 6.7L at 2,258 miles.
Let it drain 3hrs while I was doin other chores.
Installed drain plug. Filled new Motorcraft filter full of oil.
13qts did NOT read full on Dipstick, so I added 1 more qt totalling 14qts including what I poured into filter BEFORE installing.
The book wasnt right either on my old 7.3 best I remember.
I'd rather dipstick read full reguardless of book.
The book wasnt right on my KTM 950 bike either
Old 08-26-2016, 03:57 PM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
Holy thread resurrection batman! Well, since it's back from the dead, let's add that the new 2017's are suppose to take 15 qts. by the book...
Old 08-26-2016, 04:08 PM
Dakster's Avatar
Dakster
Dakster is offline
Dakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputation
Lol Rodney...
Old 08-26-2016, 05:41 PM
darren32's Avatar
darren32
darren32 is offline
darren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputation
Originally Posted by Hdslider View Post
It takes 13 qts including the filter. Tell them to read.
Still miss you buddy
  #28
Old 09-18-2016, 02:02 PM
16powerstroke6.7
16powerstroke6.7 is offline
16powerstroke6.7 is starting off with a positive reputation.
First post looks like you guys love this thread. I did my first OC on my 16 at about 2600 miles. I will go by the gauge from now on. I also switched to 5W-40 T6 Rotella full synthetic and installed and Futumo plug (valave). As the manual said 13.1 quarts put me right to the top of the hash marks on the stick.
  #29
Old 09-18-2016, 09:09 PM
ssunit1's Avatar
ssunit1
ssunit1 is offline
ssunit1 has a good reputation on FTE.ssunit1 has a good reputation on FTE.
Originally Posted by cheezit View Post
welcom to menu pricing.
So, since you are obviously more qualified than most of us, just curious if a little extra is going to cause any real issues?
  #30
Old 09-18-2016, 09:12 PM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
You're expecting a response from a post from 2012?
Quick Reply: How many qts. of oil does the 6.7 hold ??
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
