Questions about lifting 95 f 150
my 2" front spacers were $75 shipped from ebay, bodylift is around $120ish and alot more work to install then the springs or the spacers but you wont need an allignment afterwards. just make sue your rad support is not rotten or you wil ave to replace tha first before a bodylift.
for my front spacers and rear blocks i spent ~$175 in parts and still need an alignment before new tires.
Adding the spacers just move the axle the 2" farther away, of it was compressing the springs more to make it a former ride 2" spacer would be pointless. It won't change the ride quality. The f250 springs will make it stiffer.
Think of it like the rear, adding a 1" block isn't going to change how stiff the ride is, swapping 150 for 250 springs will gain a bit of height but will also make it rougher
The spring spacers go in the suspension so it doesn't affect the body/bumper it just moves the axle farther from the frame.
The body lift atually lifts the body off of the frame and spacers are between body and frame. Which is what makes the bumper gap since the bumper is bolted to the frame not the body. But you can get/make brackets to bring the bumper up to the new height of the body.
Most brand names have a "suggested" size. You don't want to go wider then the recommended size as it will be easier for the tire to pop the bead. From what I have read some guys go a little narrower then recommended ( like me puting 12.5" wide tires on a 7.5" rim) then if you go play in the rocks you can lower your air pressure and it will stay on the rim better.
Also with the narrower rim it gives the tire a bit more of a "balloon" look.
But I believe the general rule is to be around 2-4" wider then the rim. For the larger tires
#29
#30
I'd stay away from rear AAL because you'll need a kidney belt to ride in the truck if your not hauling anything. I had cheap Rough Country AAL for about two weeks before I tore them back out.
