Has the weather affected your MPG's?
Old 02-08-2012, 05:42 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,217 Likes on 800 Posts
Question Has the weather affected your MPG's?
Here in SE Virginia, our summers typically hover in the 90's and the winters in the 40's. Each year we typically get a good cols snap and it drops in the teens at night and 20's-30's during the day.
Earlier this winter we had a week long episode of colder than normal weather which hung in the low 30's all day and teens at night.
The avg MPG's on my truck for mixed driving dropped from the 18+ that I normally enjoy to around 16.5. When the weather returned to normal for us, my MPG's returned to normal as well.
Have any of you noticed any serious climatic swings in your MPG's?
Yes, I know that vehicles normally burn more fuel in the winter but the info screen on my truck drives that point home.
Old 02-08-2012, 06:11 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
Tim, remember that it's not just the environmental conditions that affects MPG. It's also the winter blend fuel, extra load (heater, defroster, heated seats), denser air, typically longer warm-ups/idle time, longer time to operating temp, etc.
I typically see a 1-2 MPG drop, but this winter has been pretty mild (I'm near Charlotte, NC) and I haven't seen much of a drop at all. Myabe .5-.75 based on my calculations.
But, I don't warm up the truck and we've had very little frost so I have barely run the rear window defroster. I have however used the heated seats.
Old 02-08-2012, 06:51 AM
meborder's Avatar
meborder
meborder is offline
Tim,
What you describe jives with what we see up here. Once we get the winter blended fuels, our mileage typicaly drops a couple numbers.
My exploder gets pretty close to 18mpg on the highway in the summer, but the best i can usually do in the winter is about 16mpg. If i drive it to work when it is really cold (below zero for highs) I sometimes get 10mpg or so because of the idle time.
they say that you don't need to idle them ... but at -29F ... yeah ... i idle for 20 minutes or so.
Old 02-08-2012, 07:34 AM
Joe Finn's Avatar
Joe Finn
Joe Finn is offline
I've seen the drop in mpg from winter fuel. Anyone know what's different about "winter" fuel? Is it really necessary?
Old 02-08-2012, 07:47 AM
FORDSVTPARTS's Avatar
FORDSVTPARTS
FORDSVTPARTS is offline
Former Vendor
I believe the governement requires a higher ethanol content in the winter time, it's to help alleviate air pollution that gets trapped closer to ground level during the colder months.
I drive an SVT Focus and I've noticed a difference in mileage every winter when the fuel blend is changed.
Old 02-08-2012, 07:59 AM
shorebird's Avatar
shorebird
shorebird is offline
Google is your friend! (I expect better from a sponsor.)
Here is an explanation of Summer Vs Winter fuel blends; HowStuffWorks "Summer-grade versus Winter-grade Fuel"
During the summer, pollution is a frequent concern due to increased levels of smog and ozone, which can harm the lungs. Summer heat boosts the formation of ozone, while the appearance of an inversion layer -- an immobile layer of air -- can trap pollutants in the lower atmosphere
Summer-grade fuel has a different Reid Vapor Pressure (RVP) than winter-grade fuel, which contributes to its being (marginally) more eco-friendly. RVP is the vapor pressure of gasoline measured at 100 degrees Fahrenheit
Because RVP standards are higher during the winter, winter-grade fuel uses more butane, with its high RVP of 52 PSI, as an additive. Butane is inexpensive and plentiful, contributing to lower prices. Summer-grade fuel might still use butane, but in lower quantities -- around 2 percent of a blend
......when do companies start producing these different summer fuels? The EPA defines April to June as the "transition season" for fuel production [Source: EPA]. Refineries switch over to summer-blend production in March and April [Source: EPA]. Gas stations have by June 1 to switch to selling summer-grade gas, while terminals and other facilities "upstream" from pumping stations have to switch by May 1 [Source: EPA]. Following the summer driving season, companies switch back to winter blends beginning in September, with the first winter increase in RVP allowance occurring on Sep. 15.
Because of the way winter and summer fuels react under different atmospheric pressures, particularly in terms of evaporation, it's important to use summer and winter fuels during their respective seasons. Fuel that's stored out of season can evaporate. It can also hurt engine performance.
Old 02-08-2012, 11:00 AM
SabreFX4's Avatar
SabreFX4
SabreFX4 is offline
Fuel blend is a factor, warm up and idle time is a factor and air temp and density is a factor. Cold air is more dense...the computer recognizes this and adds fuel to the mixture, lowering your MPG. The side benefit to cold dense air, is HP.
It all adds up and like others posting here, I usually see a reduction of 1 - 2 MPG during the winter months.
Old 02-08-2012, 11:41 AM
tseekins's Avatar
tseekins
tseekins is offline
OK cool, thanks guys for the in depth posts. I never idle to warm up unless I'm completely iced over.
Old 02-08-2012, 02:02 PM
juneau76's Avatar
juneau76
juneau76 is offline
I've found that I'm balancing out close to the summer months this winter. I'm attributing it to the fact that I travel A LOT more highway miles than I have previously. That may not be it at all, but I'm going with it.
Old 02-08-2012, 08:35 PM
Dirtysnow's Avatar
Dirtysnow
Dirtysnow is offline
I was just thinking about this a few days ago and and one thing that came to mind is the air is denser during the winter. More dense air equals more resistance and more drag. Cold air makes more power but is less efficient. Warm air makes less power but is more efficient. Can anybody verify this?
Old 02-08-2012, 09:28 PM
wolf189's Avatar
wolf189
wolf189 is offline
yep, I see the same thing here in the Chicago area every winter. about a 2mpg drop is pretty typical for me.
Old 02-09-2012, 07:15 AM
thomastl's Avatar
thomastl
thomastl is offline
I may be a little off base but I think Tim's comment was based on what I tend to see which is:
Winter time (so your already running winter fuel).
Truck warmed up already (so rich condition until engine warm is over with)
Driving down the road (so no idling to warm the engine and traffic conditions eliminated).
My ecoboost seems to get better fuel economy in 55 degree conditions than 45 degree conditions.
Driving down a 4 lane road that I travel a lot at 65 mph. Instantaneous gauge will hover at 19 on a nice warmer day. Will hover at 17 on a colder day.
Just seems that the colder air causes it to run richer for some reason and burn more fuel for the same driving conditions. I have noticed it numerous times this winter.
El Camino Man
03-07-2015 11:46 AM
98range
1983 - 2012 Ranger & B-Series
02-02-2008 10:44 PM
hammer toe
6.4L Power Stroke Diesel
01-17-2008 07:09 PM
WonderDonkey
11-23-2007 02:34 PM
captian diesel
02-26-2005 09:45 AM
Quick Reply: Has the weather affected your MPG's?
