'80-'86 FAQs (Frequently Asked Questions) Calculators, specififications, automotive terms and acronyms.
FAQ - Help! Proportioning Valve Issue?
Old 10-08-2011, 10:07 PM
ArdWrknTrk
ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
No, not anything from the plumbing department.
You need Buytl, Butadiene, or Polypropylene O-rings for Glycol based fluids.
Old 10-08-2011, 11:19 PM
v8motorcycleman
v8motorcycleman is offline
v8motorcycleman is starting off with a positive reputation.
Originally Posted by ArdWrknTrk View Post
There should be O-rings on either side of the shuttle to seal the switch from brake fluid. (at least it seems so from the drawing)
I took apart the valve a second time and there are only THREE o-rings on it. I took a picture the first time it pooped out (which I forgot I took) and there appears to be FOUR in the picture. I will try to figure out how to post and get your opinion. It would make sense that an o-rings goes on each side of the slide area for the switch to prevent pressure. Another baffling issue on how I lost a tight fitting o-ring (if that is truly the case).
Old 10-08-2011, 11:38 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Old 10-09-2011, 08:15 AM
v8motorcycleman
These are the two shots of the valve rod. The first shows four o-rings and the second only shows three o-rings. Not sure at all what happened to the third o-ring but I'm sure that will solve my problem.
Old 10-09-2011, 08:21 AM
ArdWrknTrk
pedant
Just check to make sure it didn't roll off and get packed up inside the valve body.
Old 10-13-2011, 08:00 AM
v8motorcycleman
UPDATE: I got a new o-ring and got the rod re-installed. I learned a trick that I had to pry the valve rod in by using a pick to align the valley once it was already seated on the backside. I didn't realize that the rod separated from itself and expanded even further. But, once I got that all taken care of and reinstalled, I was able to get the system back up and running!
NEXT CHALLENGE: after the truck has been sitting for a period of time, it will run for about 5 seconds and die. Then I have to play the crank it over for a minute until it starts. Tells me there is an air leak someplace in the fuel system...
Old 10-13-2011, 08:23 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Cool.
Start a new thread, this one is about brake parts.
Old 03-23-2014, 09:26 PM
blucollar4xford's Avatar
blucollar4xford
blucollar4xford is offline
blucollar4xford is starting off with a positive reputation.
Originally Posted by Franklin2 View Post
I would go to the junkyard and get a valve, or just take it out of the system...
... you can have good brakes if you want to delete it. It will be reverting it back to 60's and earlier era brakes that didn't have a valve. There are many very late 80's/early 90's pickups running with straight brake lines(including my 89), because Ford came out with a "better idea" and installed a rear anti-lock system(they didn't have a proportioning valve like yours) Like your system, it works well when it was new, but now it's old, it's very expensive and hard to find parts for, so you do what you have to, to get a truck you can use.
Hopefully not too off topic, but if one were to do away with an irreparable proportioning valve, what might the sizes/thread pitch of the brake line fittings be?
v8motorcycleman
30
12-28-2018 09:51 PM
s.squared-39
12-05-2016 04:46 PM
kameronth
08-27-2016 09:51 AM
HardFordCore
02-21-2006 11:25 PM
Tim in MD
09-24-2004 01:06 PM
Quick Reply: FAQ - Help! Proportioning Valve Issue?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
