Cheapest scanner to pull codes from the 7.3?
I guess you already know this but for others searching, code scanners won't read for trucks over 8500 pounds GVWR. I have a ford 2500 year 2000 and my Napa Innova would not connect with the truck. I called Innova tech support and that is what they told me and also read it in a few other sites
So, this comes from my PA emissions cert. Vehicles over 8500lbs are not required to have a standardized OBD system. Anything below 8500lbs has a standard system that the majority of code readers are set up for. Since 8500lbs and above are not required to have that, that is why normal code readers won't work on our trucks.
magnumak1
1999 to 2016 Super Duty
05-04-2014 06:10 PM
