Did you hear about the new 6.8L V10
2012 Ford F-650 with 6.8-liter V-10 Gas Engine - YouTube
Ford Debuts Gasoline-Powered F-650 Medium Duty Work Truck
Although Ford discontinued the 6.8-liter V-10 gas engine as an option for its 2011 Super Duty pickups, the company debuted the first application of the 6.8 engine for its 2012 F-650 medium-duty chassis truck at the NTEA Work Truck Show in Indianapolis.
Today's Ford F-650 commercial truck is offered with a Cummins inline-six diesel engine, a variation of the same six-cylinder oil burner offered in Ram HD pickups and chassis cabs. But like other diesel engines, prices for the oil burner have gone up as emissions regulations for diesels have gotten tougher. In Classes 4 to 7, prices have jumped 36 percent on average, according to Todd Kaufman, Ford's F-Series chassis cab marketing manager.
Diesel fuel also carries a premium at the pump over gasoline.
"With diesel prices outstripping gasoline by more than 10 cents a gallon in many parts of the country, the timing is perfect for a gasoline powertrain in a medium-duty truck," Kaufman said.
The powerful 6.8 is rated at a diesel-like 362 horsepower and 457 pounds-feet of torque. Instead of being paired with Ford's legacy 5R110 five-speed automatic transmission, the 6.8 will be mated with the all-new 6R140 six-speed gearbox with double overdrive gears and available power takeoff.
The gas powertrain is expected to cost about $8,000 less than a comparable diesel. Today's starting price for the F-650 with the Cummins diesel is $57,180.
Though diesel engines are generally up to 30 percent more fuel efficient than gasoline engines, Ford hopes with just the right powertrain calibrations to close that gap to as low as 10 percent with the 6.8-liter/6R140 combo, according to Kaufman.
A compressed-natural-gas option will also be available for the 6.8.
The Class 7 Ford F-650 with the 6.8 V-10 will have a gross vehicle weight rating of 30,000 pounds and a gross combined weight rating of 33,000 pounds.
Ford will start taking orders for the F-650 gasser by the third quarter of 2011. It will be available in two chassis configurations: Pro-Loader with 19.5-inch wheels or dock height with 22-inch wheels.
The F-650 and F-750 will also receive an all-new interior shared with the Ford F-Series Super Duty pickups.
The F-650 6.8 will be available to order this October, with production scheduled to start in the first quarter of 2012.
So does that mean the all-new 6R140 six-speed gearbox with double overdrive gears transmission will be avalible to us??
FOR PICTURES!!! http://news.pickuptrucks.com/2009/12...nsmission.html
Ford's technically advanced and unconventional new 6.7-liter Power Stroke V-8 turbocharged diesel will debut early next year in the 2011 Ford F-Series Super Duty lineup. No matter how powerful and sophisticated Ford's new oil burner is engineered to be, it won't be considered successful without a transmission capable of managing all of that horsepower and torque as well as efficiently sending that power to the wheels to tow and haul heavy loads. That's where Ford's new 6R140 TorqShift six-speed automatic gearbox comes in.
Like the new Power Stroke V-8, Ford designed and engineered the 6R140 entirely in-house. Al Bruck, Ford’s 6R140 transmission engineering manager, says it’s a clean sheet design and represents the next generation beyond the 2008-10 Super Duty’s current 5R110 five-speed automatic transmission.
“This isn’t an evolutionary design with limitations and we built from that,” Bruck said. “Our benchmark for the 6R140 is the current Allison 1000 transmission used in GM’s heavy-duty pickups. We’ve got greater capability than the Allison, and we’re about 25 pounds lighter.”
The dry weight of the 6R140 is approximately 325 pounds and about 350 pounds when filled with transmission fluid.
Bruck says that it’s not a single component that makes the 6R140 competitive but a series of interdependent features that add up to make this the most capable transmission Ford has ever offered in the Super Duty. We’ve broken them down into the top seven features of Ford’s all-new 6R140 heavy-duty automatic transmission.
The 6R140 uses a long-travel steel turbine damper that's welded directly to the torque converter's turbine. The damper allows the powertrain to idle as low as 900 rpm and helps control torque input from the 6.7-liter V-8 diesel
1. Works with Ford’s Gas and Diesel Engines
Unlike GM's and Chrysler's heavy-duty trucks, which use separate transmissions for gas and diesel powertrains, Ford's latest HD pickups continue to share a single transmission for both applications. The 6R140 has to be flexible and intelligent enough to accommodate the low-end grunt of the 6.7-liter diesel and higher-revving peak power curve of Ford's new 6.2-liter V-8 gasser.
How does Ford adapt the transmission for each engine? The 6R140 uses a different torque converter, clutch plates, friction paper and shift schedule software calibrations depending on the motor. That’s it.
2. Single-Piece Housing
While other transmission housings are comprised of multiple pieces bolted together, like GM’s three-piece case for the Allison 1000 transmission, the 6R140 uses a single-piece, deep-skirted case. Ford says the advantages of this design are that it’s quieter, saves weight by doing away with fasteners between body pieces and eliminates the possibility of fluid leak points at the join points.
“From the back flange of the engine block to the slip yolk at the back of the transmission is a single-piece casting,” Bruck said. “It’s a very efficient use of material for improved NVH and leak performance. It’s also much stiffer since we can eliminate the points where bending might occur.”
The only points where the transmission can leak are at the rear seal and the front seal near the torque converter.
Ford has also designed large drainage openings inside the housing to circulate transmission fluid in large volumes between the gears and clutches and fluid sump at the bottom of the housing. New friction plates in the clutches help to quickly drain fluid to reduce fluid resistance.
In the event that the transmission requires service, instead of disassembling the case like a conventional transmission, nearly all jobs start and end at the torque converter side of the gearbox. The 6R140’s components are modularly constructed to help facilitate removal from the barrel.
3. Improved Fuel Economy
Fuel economy is at the top of most truck operator’s minds these days, and the transmission plays a critical role optimizing it. The 6R140 uses several technical tricks to make promised improvements to the Super Duty’s mileage. One way fuel economy has been improved in the 6R140 is through the use of an early lockup closed piston torque converter, Bruck said.
The torque converter in an automatic transmission does the same job as a clutch in a manual transmission.
How does this improve mileage? When a torque converter is disengaged, the engine is still running but it’s not driving the wheels via the transmission, so fuel is wasted. This is important if you’re driving a vehicle with an automatic transmission, so it won’t stall at a stoplight. When you get going again, engaging the torque converter at a lower rpm means power can be sent to the wheels sooner, thereby improving fuel economy. Think of it as taking some of a manual transmission's inherent fuel economy advantages and applying them to an automatic gearbox.
"The lockup [strategy] depends on pedal positioning," Bruck said. "We've done a lot of work monitoring fuel rates at different speeds, different pedal rates and different gears to optimize the 6R140 for both gas and diesel."
The all-new torque converter helps improve fuel economy and directly links the segment-first Live Drive PTO to the crankshaft
As you might expect, there are different lockup strategies for the gas and diesel engines.
"There are advantages to not locking it up as early with the gas engine as we do for the diesel," he said. "The way we do it for the diesel, in full automatic mode, during a normal upshift, is to lock the converter between third and fourth and stay locked up through sixth. We're more aggressive locking up the torque converter earlier in tow/haul mode and manual mode."
Tow/haul mode is used in HD automatic transmissions to hold gears longer and keep engine rpms higher during towing and hauling situations so adequate power is available at all times, especially during upshifts to help prevent the truck from lugging after the shift.
Manual mode allows the driver to manually shift the automatic transmission up and down like a manual gearbox as long as the transmission doesn't exceed the engine’s rpm redline or stall the engine.
The torque converter also features a long-travel steel turbine damper that's welded directly to the torque converter's turbine. The damper, which is actually a set of springs arranged in a square pattern, limits the transmission of inertial forces produced by the 6.7-liter V-8, so they aren't transmitted to the transmission's input shaft all at once when the torque converter is locked or open. The damper allows the powertrain to idle as low as 900 rpm.
“The long-travel damper is like a long spring body that can wind up as rpms drop and diesel torque increases,” Bruck said. “And the lower the engine speed, the better the fuel economy.”
Like other competitive six-speed transmissions, the 6R140 offers two overdrive gears to improve fuel economy at highway speeds. The overdrive gears help the truck lope along at lower engine rpms.
4. Range Select and Manual Shift Functions
If a Super Duty driver wants custom control over the 6R140, they can switch from full automatic or tow/haul modes into Progressive Range Select or Manual modes. Range Select is activated via a toggle on the shift lever that allows the customer to reduce the range of available gears while in Drive. When the customer “taps” down into Range Select mode, the display shows the available gears and highlights the current gear state. This feature allows the driver to limit use of upper gears when heavily loaded or while towing on grades. It’s especially helpful in terrain that includes constant hills when towing.
In manual mode, the driver can select the exact gear they desire, as long as they don’t go over redline. The display will show the selected gear, and the control system will lock the torque converter and hold that gear for a full manual transmission feel. Manual mode is Ford’s way of making up for the loss of a standard ZF six-speed manual transmission, which goes away for 2011.
5. Live Drive Power Takeoff
Ford says the 6R140 transmission will be the first gearbox in the segment to offer what it calls Live Drive Power Takeoff.
Power Takeoff is used to power auxiliary tools, like generators or salt spreaders, off of the engine.
By linking the PTO’s output gear directly to the engine crank via a flex-plate connected to the torque converter housing, the PTO output gear continues to turn as long as the engine is turning, even if the truck is completely stopped and the torque converter is disconnected to keep the engine from stalling. In the outgoing 5R110, the PTO is linked directly to the turbine shaft.
“It’s capable of mobile and stationary PTO,” Bruck said. “This will enhance the capability of PTO products that are available today.
6. New Ravigneaux Powerflow Gearset
The power-dense sinter-brazed Ravigneaux gear carrier manages the torque of the new 6.7-liter diesel and the high-speed shifts of the new 6.2-liter gas engines
The 6R140 uses a new tough sinter-brazed Ravigneaux planetary gearset to carry engine torque without artificially limiting torque at launch to preserve transmission hardware. It’s a stout compound set of interconnected gears that acts as a two-in-one gearset, with one planetary carrier that’s common to two sets of planetary pinions, two sun gears and one common ring gear. It’s also capable of handling the high shift speeds of the gas engine and high torque loads of the 6.7-liter diesel.
“This gearset has plenty of headroom,” Bruck said. “It’s not stretched with our launch torque limits. When you see it side by side with the Allison’s gearset, you’ll say that these guys are playing in the same sandbox.”
The powerflow gearset’s housing is made from powdered metal. Normally used to create components like an engine’s connecting rods, a metal powder is poured into a mold and heavily compressed with a mating die. When it’s removed, a binder holds the powder together; it’s then sintered into its final form, which is nearly as dense as steel. It can be double-pressed again after sintering to make it stronger through greater density. Powdered metal provides all of the features of a steel part without requiring machining.
A Ford-patented rocker one-way clutch is integrated with the torque carrier and helps improve 1-2 shift quality through the gearset. It’s carried over from the 5R110 transmission.
7. 150,000-Mile Maintenance Schedule
To help lower operating costs, the 6R140 uses an internal “dual-media” filter that’s split into two mesh components – a coarse-grained filter and a fine-grained filter. The coarse-grained filter cleans about 90 percent of the transmission fluid in the gearbox while the fine-grained filter continuously cleans about 10 percent of the volume. Over time, both large and small contaminants are removed from the fluid, extending its maintenance cycle to 150,000 miles. For comparison, the current 5R110 has a 60,000-mile change interval.
“The concept is that over time you get a very effective cleaning,” Bruck said. “You don’t have to draw everything through the fine media, which is very inefficient and doesn’t work well in cold conditions. The dual-media setup uses a pressure balance to draw fluid into the fine media while everything goes through the coarse media. You reach an equilibrium of very clean fluid over time.”
Main control assembly and new dual-media filter with 150,000-mile change interval. Note how these components are located inside the single-piece transmission case.
The internal dual-media filter removes the need for an external filter, which also eliminates another potential leak point for the transmission.
“We studied doing a spin-on [filter], but the numbers we collected proved we could do it all internally,” he said. “Now we’re working to see if we can push the [maintenance interval] number even higher.”
One interesting point about the transmission fluid used in the 6R140 is that Ford has created a new standard that will see most of its vehicles use the same transmission fluid regardless of application. Transmission fluid for the Super Duty will be the same as the Ford F-150 half-ton pickup and other vehicles like the Ford Fusion sedan and Ford Escape.
“There’s been a lot of work done to migrate all of the vehicles to the same common fluid,” Bruck said.
CHECK THIS OUT
http://media.ford.com/images/10031/SD_6Speed_Trans.pdf
CHECK THIS OUT
whats the differents between
slip yoke flange yoke
slip yoke http://www.automotix.net/usedtransmi...f625&seq_num=4
flange yoke http://www.automotix.net/usedtransmi...db9a&seq_num=5
FOUND THIS I DID DO THIS IT WAS ON ANOTHER POST
Using the calculator provided above and the standard 32.1" tires, at 70 mph, here is what I come up with:
Ford the 6R140:
Top (6th) Gear (0.67:1):
3.31 - 1625 RPM
3.55 - 1743 RPM
3.73 - 1831 RPM
5th Gear (0.85:1):
3.31 - 2061 RPM
3.55 - 2211 RPM
3.73 - 2323 RPM
For the 5R110 (0.712:1):
3.31 - 1722 RPM
3.55 - 1847 RPM
3.73 - 1940 RPM
I wouldnt be shocked if alot of buyers make the switch! Especially with the potential 10% difference in mileage.
I think even if fuel mileage stayed the same, business that maintain fleets are starting to realize that for many of the applications, diesels no longer make sense. My stepfather's oil and gas company, for instance: they keep a small fleet of all ford F250/F350 utility and pick up trucks for servicing drilling rigs and wells. They hardly ever use them to tow trailers as they have heavier cdl trucks for that, and he told me the new ones have more problems than the old 7.3's used to so they are starting to trade them out every few years when they get about 100k on them. Plus he said the mechanics in their garage aren't as good working on the new ones (like the dual cooling systems and stuff) so they end up having to pay the dealer or outside help to fix complicated problems. Most of their trips are not too far away. I think gas engines would be cheaper in the long run, and he agrees with me, though they are still using diesel for now. A natural gas option might make even more sense for them, since they get it free (and prices are so low right now).
Think about it. in the summer when the better gas comes i can get up 2 12.5mpg. now 10% is 1.25 so thats 13.7 approx. adds up to 546.92 miles a trip in perfect conditions. (dreaming i know) so if i can go an extra 49 miles to a tank. now i drive about 1100 miles a month so that one month i will have to fill up twice instead of in the end before the end of every month fill up again. this would cut down my gas bill greatly. gas right now is 3.54 thats About $311 conmpared 2 before trans about $396 almost every month. SAVED $85 dollars now times that by 12 (12 months) equals $1020 saved not bad not bad at all. plus the trans is almost paid off. i am never selling my EXCURSION NEVER!!!!
it would be a wise investment i should of started last year when the new trans came out and my old trans went pooie on me. it would be almost paid for this year now!
