First Post/New Member
Old Feb 5, 2012 | 04:49 PM
Eggman63's Avatar
Eggman63
Hi all! I just purchased this afternoon a decent 84 xl 2wd short bed.This truck has been sitting for 6 years.I put a batt. in it dumped 5 gals of gas and it fired up on the first try.This truck has the TOD 4 speed in it with a bad 3rd gear.I can rebuild it but I am planning to drop my new 340 hp FRPP crate engine in it.I don't think this tranny will really be ideal for this engine,and I was wondering if I could somehow finagle a T-5 in its place.
Old Feb 5, 2012 | 06:33 PM
Gary Lewis's Avatar
Gary Lewis
Eggman - Welcome! I don't know anything about the T-5, but I'll bet someone here does. I'm sure you've come to the right spot.
Old Feb 6, 2012 | 08:10 AM
Grubbworm's Avatar
Grubbworm
Welcome to the forum Eggman63.
Old Feb 6, 2012 | 08:48 AM
f100beatertruck's Avatar
f100beatertruck
Depends how you drive it. I'm assuming you're talking about a world class T-5 from a Mustang. The T-5 was designed when the mustang was making 150hp... They regularly "popped" when drag raced with stock 230hp engines. It will likely hold up if you shift it easy; that is, take you foot off the gas between gears... I would say the T-5 is marginally stronger than a RUG but it's going to be the weak link here. Remember, it was designed around a 150hp, 2,900lb car... Not a 340hp, 3,900lb truck.
Old Feb 6, 2012 | 08:54 AM
Gary Lewis's Avatar
Gary Lewis
What he said. I read this link and came to the same conclusion T5 Transmission - Car Craft Magazine. However, it can be built to stronger specs, but why not start with something designed for a truck in the first place?
Old Feb 6, 2012 | 09:05 AM
Yaga1973's Avatar
Yaga1973
Elder User - What???
Welcome to the forum and I second (or third) the opinions that a T5 is not what you want. Go with a truck transmission and learn how to shift them a little faster (but nicer at the same time).
Old Feb 6, 2012 | 09:06 AM
f100beatertruck
It can be made a lot stronger but for the cost you could get a Tremec TKO 500/600 trans or for a little more a T56. There is a reason the beefed up T-5 parts exist, Factory Stock drags mainly. I want to say it's around $1,000 for all the upgrade parts plus install and a good T-5. Assuming you don't have a T-5, going from memory it's around 1,800-2,000. For a couple hundred more you can get the TKO 500.
Also, the TKO takes the earlier toploader bellhousing. The T-5 uses it's own. You didn't say what engine you have but you may be able to reuse your existing bell. 5.0 and 5.8w are the same, and I believe the 300-6 is too. That should also simplify the swap as you can use your existing clutch parts.
Old Feb 6, 2012 | 09:10 AM
lavatan's Avatar
lavatan
Welcome to the forums Eggman. If you're wanting to tow with the truck a Borg Warner T-19 transmission will do ya fine. I have it in my truck and am happy with it. If you want it as a daily driver and want overdrive a ZF5 will be what you're looking for. Take a look around. I think you'll want to stay away from a transmission built for a lightweight car unless you're going to turn the truck into a dragster...
Old Feb 6, 2012 | 09:13 AM
f100beatertruck
Tremec built the 3550 trans on spec to be a truck trans. It was only luck for them that someone decided it would be a good HP mustang trans. That trans morphed into the TKO line. They also did eventually use the 3550 in jeeps I believe.
I'm assuming that with a 2wd shortbox and a 340hp engine he's not looking for a work truck capable of hauling a ton of roofing tearoff...
I'm sure the T-5 could be made to work and live for a while if driven right but it's not ideal.
If you have a good T-5 or can get one cheap and that's all you can afford, avoid the powershifts and drag starts. You may get lucky and it'll last for a while, but at the same time I would be saving up for a better trans. The TKO, for a performance application is hard to beat. Your other option is a truck trans. They're going to be slower shifting and probably don't have the optimum ratios for a "performance" truck but they should hold up.
Old Feb 6, 2012 | 09:29 AM
Yaga1973's Avatar
Yaga1973
That's cool to know, thank you. And yes, TKO's are much better.
Old Feb 6, 2012 | 12:55 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
Welcome to FTE! Either you're a John Waters fan or you like Sonic the Hedgehog or... but this is all I heard when I saw your screen name
<embed src="http://www.youtube.com/v/aQ43Zws-Dso?version=3&hl=en_US&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="420" height="315">
Old Feb 6, 2012 | 01:49 PM
lavatan's Avatar
lavatan
I just watched the video.... Ummmm... What the heck did I just watch? Looked like a PSA that needed to be on MST3K and brutally made fun of. Was that large woman in a baby crib? Why was she in a baby crib? Who the heck is the woman in the dress? Caretaker? Did the egg man eat paint chips as a child? So many questions... I think I need to go lie down.
Old Feb 6, 2012 | 01:53 PM
Gary Lewis's Avatar
Gary Lewis
And, if that was John Waters, why did he have fans? Didn't look hot to me so shouldn't need to be cooled off.
Old Feb 6, 2012 | 02:31 PM
Eggman63's Avatar
Eggman63
Thanks for the replies.And yes ,this is going to be a hot rod truck.I was actually trying to figure out how the trans would line up in the truck as in where would the shifter come up trough the floor.I have used T-5'S in alot of 85-86 Mustang GT's and have never broke one.If I could beef up and change the gearing in the RTS trans in the truck that would also be a viable solution.
Old Feb 6, 2012 | 02:42 PM
Yaga1973's Avatar
Yaga1973
Um, yeah. I'm not really sure what that video was. I am now scarred for life. I did share it on facebook, though.
