Cavitation. Block Worm. The Expensive Death. A MUST READ!
Cavitation. Block Worm. The Expensive Death. A MUST READ! - Oilburners.net
Here is a really good read on cavitation. I am not going to lie having three 7.3l used trucks I am a little worried.
on
its a good one!
i have a link to that in my sig below too,called "Maintaining Coolant For The IDI".
as for fearing cavitation.don't.it's fairly rare,even though it's talked about very often.
as long as you maintain the coolant,the 7.3l will hold up.
the first gen,and even some early second gen PSD 7.3l's need to run traditional coolant with sca's too.
after that,they went to ELC coolant of course which combats cyl wall erosion differently.
see "Adding a Coolant Filter to the IDI Cooling System" to learn how to have an advanced coolant filter keep care of this for you.
6.9l guys tend to think they are exempt! that's the most dangerous problem imho,because the walls are still attacked.they can,and have been known to fail due to cavitation too! perhaps less worse,a 6.9l block may be doomed from being rebuilt because cly wall's are have been eaten too close for comfort.since they are the preferred block to start with for rebuilding an idi,that would be a shame.
lets go pats!!!!
lets go pats!!!!
on
HEAVY DUTY FORMULA:
ATLAS Perma-Guard® Universal Antifreeze/Coolant Precharged with Supplemental Coolant Additive (SCA) meets the heavy duty requirements: ASTM D3306, D4985, and TMC RP329.
Team TBA
sounds good.
one of the more commonly used is fleet charge,which is found at stores like tractor supply and napa.
Fleet Charge Specifications Sheet
interesting.the link in my sig works for those have not read the article yet.here it is directly:
http://www.oilburners.net/articles/cavitationartic.html
as presented.it is indeed a MUST READ.
