59' F100 Drag Link Help
Perhaps this is an easy question for some, but this is my first F100 build using some aftermarket suspension parts so need a little direction. I'll attach some photos to go along with this so everyone can see what I'm looking at. That said, I'm looking for drag link that measures 12 1/2 inches from center of tie rod end to center of tie rod end and not really sure how to go about finding one. Is this a custom made drag link or maybe there's a production vehicle that has something this size already that I can use?
Here's some details in terms of the part I'm using which you'll see in the photos:
- PMT Fabrication 3" dropped axle
- Factory style F150 disc brakes (calipers/rotors)
- Posie Super Slide lowered leaf springs (stock mounts)
- CPP Power Steering Box kit (Toyota style) with CPP Pitman Arm, etc.
- Also worth noting, which you'll see, is the steering arm that the drag link connects to is routed differently than the stock style. Same type as the original but instead of running toward the front and curving around, it runs toward the pack and curves toward the front.
- The drag link you see connected in the picture is the one that came on the dropped axle when I purchased it which is obviously too short. It was on a 55' F100 - in case you were wondering...
I hate to make a comment on something I know nothing about, but looking at the steering arm that raps to the front it looks like that is for a drag link that moves left to right and not forward and back.. I just see how it would work even if you had the correct length drag link to connect the two?
ewy00
08-08-2021 11:41 AM
Otis 54
05-21-2011 09:33 AM
jrod60
12-21-2010 05:15 AM
inlandsurf
04-30-2008 08:45 PM
