Pulling a BIG 5th wheel with a SRW F-350
#32
Sorry to hear about your wreck, from the look of your avatar it was pretty serious. I hope nobody was injured, I would hate to be on the receiving end of that wreck in anything smaller than a dump truck.
#33
#34
#35
18" or 17" wheels would give you the best RPM's and torque.
Airbags...you want something that you can control each bag independently. A dual controller.
You also want at least a gal on board tank so that your compressor does not have run alot. The tank you also want an aux off of it so you can run a hose off it to fill up tires if you have one that is low or have bike tires and stuff.
So a dual control, a heavy duty compressor, 1 gal tank and air bags.
#36
#37
#38
#39
Pin weight (the load carried by the truck) should typically be around 20% of the total trailer weight. If the pin weight is what you said earlier, you should be fine with SRW. If it's up near 3000 or higher, I would say you need a DRW without a doubt. Only way to know the real pin weight is to put it on a truck scale.
#40
We currently don't offer any controllers that are designed to work with compressors and tanks already installed. However, the kit alone comes with plumbing to allow you to manually fill the bags from outside the truck. Depending on how much money you wanted to spend you could just run a line from the tank on board to fill the bags up with a standard shrader valve attachment.
As Senix mentioned, I would also recommend a dual controller. This would give you the ability to independently adjust each side. At a minimum I would suggest kit 25852. If you already have a tank and compressor I can put you in contact with the right place to just buy pieces of the kit you need. You would have to run a valve in place of the kit compressor, which is what I believe Senix is running.
#41
You are going to end up on your lid.
12500@20%=2500 [12500@25%=3125] 16800@20%=3360 [16800@25%=4200]
Get a duelly.
Investigate static loads and dynamic loads and buy some reserve capacity.
Actually, as long as it has lite up mirrors and chrome bits its probably good to go.
Get a duelly.
#43
#44
I have the bags and I would get them even with the F350. I would opt for the firestones with dual command.
#45
I'm curious what makes it troublesome for you. I drive an F-450 as my daily driver and I have zero issue. No more issue than I'd have with a 4-door longbed anything else. Actually, in my case probably a bit less because the 450 turns on a dime because of the front axle.
